quick SAS questions
Old Mar 23, 2007 | 04:23 PM
HAVOC's Avatar
quick SAS questions
Why are wheel spacers needed on the front axle when doing a SAS?
Is it for fender rubbing or caliper clearence? Do all companies include spacers, or do you need to measure backspacing to see what thickness spacer you need?
Thanks on any info...
Old Mar 23, 2007 | 04:54 PM
cootees's Avatar
The most common sfa to use is the pre '86 axle. Which is not as wide as the rear axle on the ifs trucks, hence the need for the wheel spacers.
Someone correct me if I am wrong but I think if you use the sfa out of an fj80 then it is the same length as the rear axle. Eliminating your needs for the wheel spacer. Of course it is much harder to find and more expensive if you do find one.
Old Mar 23, 2007 | 05:14 PM
waskillywabbit's Avatar
Matching the rear IFS axle width and so you can run larger calipers and to keep big meats off the springs.
Old Mar 24, 2007 | 05:06 PM
4Crawler's Avatar
Don't necessarily need spacers. But some reasons to use them, as mentioned above is to match the rear axle width (IFS rear is 3" wider than a solid front axle). Or if you want to re-use your stock wheels, they have too much backspacing to clear the calipers and steering arms on the solid front axle. Other options are to run a wide-vented brake kit up front, gets the wider track up front with the spacers part of the wide-vented rotor kit.
Old Mar 26, 2007 | 08:57 AM
Kaleb's Avatar
The wheels will hit the calipers when you try to put them on without wheel spacers.
Old Mar 27, 2007 | 03:26 AM
HAVOC's Avatar
thanks everybody!
Old Apr 25, 2007 | 07:45 PM
-TheBandit-'s Avatar
I did my SAS and haven't installed front wheel spacers. I'm using vented rotors and IFS calipers without any clearance issues. My wheels are aftermarket. I can't see the width difference front and rear unless I take out a tape measure.
Old Apr 25, 2007 | 08:31 PM
Kaleb's Avatar
Are you using the ifs hubs?
Old Apr 26, 2007 | 10:23 AM
UKMyers's Avatar
Be sure to check out Skye Manufacturing widening kit. It is alot better set up than spacers and you can use your IFS hubs with it.
thefishguy77
Aug 9, 2015 04:15 PM
boogiewoogie
Jul 24, 2015 05:10 AM
yourrealdad
Jul 21, 2015 11:13 AM
icentropy
Jul 14, 2015 10:23 AM
