Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
upgrade headlights for 87 22re p/u
This is my first post.. Just joined today, but been visiting for months.
I am picking up my rebuilt engine tomorrow, and now is the time to make some other changes. 1 major issue I have is night visibility. My headlights suck. Ive been told if I want to go LED I may have to change all the wiring. I would like to know what are the best, brightest headlights i can use that are just plug and play, no rewiring. Any suggestions? |
| Sponsored Links |
#2 (permalink) |
__________________
2000 4Runner Limited 4x4 "TRD". Blown, etc. 1988 Trail Truck. SAS, Dual Cases, Exoed, Aluminum Trail-Ready Beadlocks, 37" Boggers, and Extreme Rock Rash. 2008 Camry LE. |
#3 (permalink) | |
Quote:
Any other ideas? |
#4 (permalink) |
Yours would be a 1st gen. 4Runner. (basically the same as a 2nd gen pickup) I used an H4 headlight upgrade in my '85 and it works well:
- http://www.4crawler.com/4x4/CheapTri...l#H4Conversion Best thing you can do is a simple relay wiring harness upgrade: - http://www.4crawler.com/4x4/CheapTri...#WiringHarness
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs. r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club Last edited by 4Crawler : 05-16-2008 at 01:56 PM. |
#5 (permalink) |
i run the roundeyes w/ 100w highs and they work great
w/ some hella 500's ![]()
__________________
1994 toy 22re- http://www.yotatech.com/f86/nocalsvx-s-94-toy-104593/ 2006 Subaru Forester XT -some mods/awd 5spd 1994 Subaru SVX- hwy runner 84 RX7- drag car build |
#6 (permalink) |
1st gen = 79-83
2nd gen = 84-88 3rd gen = 89-95 4th gen = 95.5-2004 (tacoma) 5th gen = 05-current (tacoma) i think you are covered. as they fit my 88.
__________________
2000 4Runner Limited 4x4 "TRD". Blown, etc. 1988 Trail Truck. SAS, Dual Cases, Exoed, Aluminum Trail-Ready Beadlocks, 37" Boggers, and Extreme Rock Rash. 2008 Camry LE. Last edited by netwt12 : 05-16-2008 at 01:50 PM. |
#7 (permalink) |
Just get yourself a quality par of H-4 lights, upgrade your harness and you'll be good to go. I run Hella housings with PIAA extreme white lamps, and I love the combination!
__________________
Raj : 1960 Homo Sapien. 192cm, Blonde, Blue. Soon to lose spare tire. Worf : 1990 SR5 Xtracab 4x4 5 speed, Inca Red Metallic. 3.4 converted, with Taco 5 spoke alloys, 275/65R16 BFG AT K/Os. Soon to add rear e-locker. |
#8 (permalink) |
Frugal upgrade: Sylvania XtraVision H6054's! Bright! Good pattern, and long lived. Easy to install.
The "relay wiring harness", mentioned above, is highly recommended. |
#9 (permalink) |
I have some clear headlights on my 3rd gen. I also installed 170/100W IPF H4 bulbs and made a new wiring harness for my lights with Hella H4 connectors and good wires.
The light output is amazing, my buddy has a HID kit in the same light housings and my beam pattern is much better, so my lights actually work better than his HIDs. |
#10 (permalink) |
I took a set of Blue lens H4 headlights that I bought off E-bay for my 91 Prelude years ago and put them in my 88 Toy.
they pluged right in, you can change out the bulbs, it came with a city light built in. they where like 9.99 and I had them on my toy for 4 yrs until I sold my rig, they worked great. nice upgrade over stock! |
#11 (permalink) | |
Quote:
After installing the Hella H4 lamps, install a simple set of relays to boost the headlight voltage, and you're set. Need help with wiring or relays? Hit up your local stereo shop they can do it for you. If you feel the need for more lighting (after relays) you can swap the bulb wattage to whatever you want, as long as you don't leave the highbeams on when the vehicle is stopped or else you risk melting the headlight plugs themselves.
__________________
- Brian |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 86 4runner 22re Altinator upgrade | 90Runner | 84-85 Trucks & 4Runners | 0 | 01-29-2008 01:11 PM |
| Anyone have these 4runner projector headlights or crystal clear headlights?? | afdj006 | 95.5-2004 Tacomas & 96-2002 4Runners | 13 | 11-01-2007 09:02 PM |
| Whats the best cam for 22re upgrade??? | black diamond | 86-95 Trucks & 4Runners | 17 | 10-14-2007 08:01 PM |
| What's up w/ my headlights? | PhillipsRA | General Electrical & Lighting Related Topics | 7 | 07-01-2007 07:41 PM |
| Ways to upgrade headlights on my 02 Tacoma? | Ghetto2315 | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 02-08-2004 08:24 PM |
