Starter issues in 3VZE - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Vehicle Related Topics (Non Year Related)
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-25-2009, 06:58 PM   #1 (permalink)
j0rdanisme's Avatar
Hey guys,
I was recently cruising to the airport, got lost, turned my truck off and it would not turn over again. My stereo works, along with the lights ect. When i put a charger on the battery nothing changes.
Im thinking its my starter. The engine does not even crank over, so thats a pretty good sign (correct me if im wrong). How could i resolve this? I've heard of hitting it with a hammer temporarily helping it, does that work?
Thoughts?
__________________
91' SR5 V6 - Soon to be Baja!
j0rdanisme is offline
Old 10-25-2009, 07:09 PM   #2 (permalink)
4Crawler's Avatar
See below for some ideas:
- http://www.4crawler.com/4x4/CheapTri...shtml#EasyTest
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 10-25-2009, 07:39 PM   #3 (permalink)
j0rdanisme's Avatar
Thats more of a walkthrough on how to rebuild it, i need to get my truck home before I can rebuild it
__________________
Old 10-25-2009, 08:42 PM   #4 (permalink)
4Crawler's Avatar
Try a hammer or something to tap on the solenoid in case the plunger is stuck. You can also make a jumper wire to bridge power from the starter power post to the solenoid it to turn over, have someone in the vehicle turn the key to the start position then use the jumper:
- http://www.4crawler.com/4x4/CheapTri...shtml#QuickFix
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 10-28-2009, 02:57 PM   #5 (permalink)
j0rdanisme's Avatar
Hey guys, quick update as i am severely confused now.
So, when my truck is cold it will start fine. When its hot it wont start.
The ONLY thing i can SEE that could cause this is the heat wrap around the cabling beside the exhaust manifold is all cracked and worn out. Could that cause it?
Im lost on this one.
__________________
Old 10-28-2009, 03:01 PM   #6 (permalink)
4Crawler's Avatar
If possible, try the voltage test I linked to above. Do the test when cold, note the voltages when it starts. Then test the voltage when hot and see if there is any difference from the cold tests. If so, the problem will lie in the circuit where there is a voltage difference.
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 10-28-2009, 03:11 PM   #7 (permalink)
j0rdanisme's Avatar
Quote:
Could heat directly effect the power input/output?
I will try it for sure.
__________________
Old 10-28-2009, 03:20 PM   #8 (permalink)
4Crawler's Avatar
Most normal materials have a positive resistance vs. temperature curve, that is higher temps = higher resistance. And higher resistance translates to increased voltage drop in a circuit. The solenoid, for example,pulls about 20 amps when it is on. And, per the FSM, more than 0.5 volts of drop in that line is a cause for concern, and with V=I*R, or R=V/I, you have 0.5/20 or 0.025 ohms between the battery and the starter solenoid will cause 0.5 volts of drop. And things like corroded connections or wires that are corroded up under the insulation have an even more extreme resistance vs. temperature curve.
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 10-28-2009, 03:33 PM   #9 (permalink)
Kiroshu's Avatar
Go buy you a hammer from wallbobs and hit the starter when your truck won't turn over. If it turns after hitting it then the starter seems at fault. Clean battery terminals. Check voltage when hot and cold.
__________________
My current:
1986 Toyota 4runner
SR5 EFI
4cyl 2.4L 22RE
5-Speed
242,000 Miles
95% Stock
__________________
(Still working on restoring her)
My old:
1988 Toyota 4runner
SR5
EFI
V6 3.0L 3VZ-E
5-Speed
302,000 Miles
All stock
(sold)______________
(Was my fastest truck i miss her...)
My old:
1989 Toyota 4runner
Non-SR5
EFI
4cyl 2.4L 22RE
Automatic
231,000 Miles
(was my quietest and slowest yota.)
Kiroshu is offline
Old 11-03-2009, 11:23 AM   #10 (permalink)
j0rdanisme's Avatar
Figured out the issue.
The housing around the solenoid connection was all cracked and broken, making it shake and rattle when driving. Oddly enough heat effected it. Fixed!
__________________
Tags
3vze, 89, location, solenoid, starter, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
