converting biodiesel back over to diesel
im looking to buy a car that has a biodeisel conversion done to it and i was wondering if it was possible to convert it back to plane old deisel. please help.
What do you mean by the conversion? The only thing needed on older diesel engines to run bio is upgrading the fuel lines to Viton lines. If that is all that was done it won't effect the use of normal diesel. BTW - if it is an older diesel you'd have more to worry about from ULSD diesel now on sale - lots of anecdotal reports or pump failures on older diesels.
Even veggie will just run on reular diesel as the conversion just adds heaters to keep it liquid.
But x2 on the "why" ... if I had a diesel I would be trying just about anything to run bio ...
one of the veggie conversions uses the coolant to heat the veggie oil and has dual tanks (factory tank for diesel to start and warm up on till the veggie starts flowing and to run on before shut down to clear the line of veggie, the other to hold the veggie oil - if that makes sense) -- so to free up trunk space maybe?
skoti89
07-08-2015 12:05 AM
Jnkml
07-06-2015 01:20 PM
