Idler bearing removal ??
Old 04-24-2011, 11:02 PM
IDRUNNER's Avatar
Finally got bolt out of crankshaft and in process of removing idler bearing. Is it easier to remove cam sprockets and take off back plate to get to the bolts?? The metal vacuum tubes run over the top of those bolts. I can't see another way to get at 'em. 89 runner 3.0 manual.... Thanks!!
Old 04-25-2011, 12:55 AM
Staff
DeathCougar's Avatar
Take off that upper plate, and you can remove that upper idler. Its a major PITA and would be best to use some wobbly sockets (not the U-joint extensions, but the wobbly sockets)
I did that on my 1990 many years ago without removing the upper intake.
Old 04-25-2011, 06:22 AM
IDRUNNER's Avatar
Thanks for the reply. They sure didn't leave any room to get those bolts out. I can't even fit a wrench in to get at one of the bolts. Tight, tight, tight!! That's why I was thinking of taking off the back plate.
glowz825
01-25-2022 09:28 AM
bigjstang
08-25-2021 12:41 AM
09-04-2015 09:27 AM
norcal98
08-10-2015 06:20 AM
TJWilly
07-31-2015 02:05 PM
Quick Reply: Idler bearing removal ??
