Sponsored by: CARiD
Timing belt!
Old Apr 24, 2011 | 04:31 PM
kyboy's Avatar
Timing belt!
I just bought a 98 4runner and im wanting to replace the timing belt. can someone tell me what all i will need to do and replace? are there any kits with everything that i would need i could buy?
Old Apr 24, 2011 | 04:56 PM
Elton's Avatar
get this and just do everything while its apart
http://cgi.ebay.com/ebaymotors/Toyot...Q5fAccessories
Old Apr 24, 2011 | 06:08 PM
kyboy's Avatar
will i need any special tools??
Old Apr 24, 2011 | 10:56 PM
IDRUNNER's Avatar
I'm in the middle of changing my belt. No special tools so far . All metric 10,12,14,17,19mm will get you. You may have FUN getting the bolt out of the crankshaft. SOAK in PB Blaster!!! I wound up taking a piece of alum I had and drilling holes to line up w/ bolts in harmonic dampener and blocking against the frame, to stop crank from turning. Breaker bar and 2' cheater pipe FINALLY worked. Next test is getting cam pulleys off!!Good luck!!
Old Apr 24, 2011 | 11:09 PM
vital22re's Avatar
totally a bro
you need new crank bolts, or at the very least some lock tight on it. I believe it calls for 220 ft lbs for that bolt.
Old Apr 24, 2011 | 11:48 PM
Elton's Avatar
you will need to fab up a tool to hold the crank and if u have access to a 1/2'' impact gun a good one it should break it loose
Old Apr 25, 2011 | 08:03 AM
kyboy's Avatar
Thanks for the information i will need all i can get lol
Eggslinger
Jun 8, 2019 03:32 PM
thefishguy77
Jul 30, 2015 10:59 AM
nick b
Jul 11, 2015 04:38 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
