5.5" rear coil springs on 94 4runner?
Old 12-25-2005, 05:48 PM
paintball11090's Avatar
I have a 1994 4runner, my only suspension modifications are procomp es3000 shocks, low profile bumpstops up front, and 31 10.5 15 bfg at.
I am looking around for a "cheap" suspension lift. I was looking into the 1.5" coil springs when I found 5.5" lift coil springs which I have never seen before and I was wondering what else I would need in the rear to use them, and what would be a "cheap" way to lift the front to make it look even.
thanks,
Greg
Old 12-25-2005, 05:55 PM
rocket's Avatar
Have you tried searching yet? This subject has been talked about a billion times.
Pick one: https://www.yotatech.com/forums/showthread.php?t=54794
Old 12-25-2005, 05:58 PM
but will i need to replace my shocks?
Old 12-25-2005, 06:19 PM
rocket's Avatar
I don't think you would since you already have ProComps.
Just give them a call and order what you need/want. Phil (stap22) is a cool guy and really helps everyone. I ordered one of his lift options w/out the BJ spacers because i already had them. Still got a killer deal.
Based on your sig, i'd suggest getting either Old Man Emu or Downey springs for the rear and Ball Joint spacers up front. You might need a panhard drop too.
Old 12-25-2005, 08:52 PM
Robinhood150's Avatar
Moved to newbie section.
Old 12-26-2005, 06:59 AM
anthony1's Avatar
If you're going from stock to 5.5 coil spring, you BETTER change your shocks too. It'll be pretty short for that 5.5 lift.
Old 12-26-2005, 02:11 PM
thanks alot that is what i was thinking but i wasnt totaly sure
Old 12-26-2005, 10:43 PM
rocket's Avatar
What are the 5.5" springs you found?
Getting new shocks may not be necessary since the Procomps you have are already designed for a lift.
06-01-2021 01:51 PM
lledwod
08-30-2016 01:03 PM
Jnkml
07-06-2015 01:20 PM
Vargntucson
07-04-2015 12:15 PM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: 5.5" rear coil springs on 94 4runner?
