1992 4runner Rough Country Lift!!! Bad Idea? Doesnt seem right!!
Old 12-07-2009, 10:18 PM
David_mx70's Avatar
Ok so i thought i would go with the rough country 5in lift on my 1992 4runner i just bought to save a little $$$ but i just got the rear done other than installing the shocks that do not fit!!! it seems like the rear wheels are a little farther forward in the wheel wells than they should be? it came with new extended upper rear arms but no lower arm brackets! does that seem right to all you?? it sure dont seem right to me (seems like all other kits have em) what should i do to fix it without ruining the geometry? i included a pic of it, there is no bumper so it looks even worse but its about 1.5 in farther forward measured from the tire to the fender curve.
Attached Thumbnails 1992 4runner Rough Country Lift!!! Bad Idea? Doesnt seem right!!-img00182.jpg
Old 12-08-2009, 04:57 AM
vandert's Avatar
Taht's pretty standard across all the lifts man, it actually helps with the driveshaft issue's, but there are aftermarket arms out there somewhere, seen them on here but don't remember where, seems they aren't to pricey either.
Old 12-08-2009, 02:31 PM
JamesD's Avatar
From the looks of the instructions, it does not have a lower control arm drop bracket:
http://www.roughcountry.com/install/736S.pdf
Old 12-08-2009, 02:53 PM
flashkl's Avatar
Nothing wrong with that, as the spring compresses the control arm moves the axle back, if you moved it back you would rub when tucked.
Old 12-08-2009, 08:49 PM
nlouvros's Avatar
sorry to jack this thread...but i keep asking rough country if this lift will fit on a 91 hilux surf...but no one knows there...this kit must fit a hilux surf, shouldnt it!?
Old 12-08-2009, 10:17 PM
David_mx70's Avatar
Hey guys thanks for the help, first 4runner ive had so i wasnt sure
Old 12-09-2009, 06:05 AM
flashkl's Avatar
4runner = hilux surf. Yes it will fit
Old 07-03-2013, 04:56 PM
OhBoy's Avatar
Thanks Everyone... I am about to do R/C 5 inch IFS lift front and blocks in the rear this weekend.You have saved me from the same question!
6th Gear
19
12-10-2019 07:31 AM
voiddweller
19
05-02-2016 09:10 PM
Alex Bessinger
06-28-2015 10:05 AM
Mack
07-16-2002 11:02 AM
HALMAN
06-14-2002 09:02 PM
Quick Reply: 1992 4runner Rough Country Lift!!! Bad Idea? Doesnt seem right!!
