Where is the No. 5 water by-pass hose??
Hey all
My very first post here - I'm just getting started removing the heads from my 92 V6 4x4 - and using the FSM step 18(e) says to "remove the No. 5 water bypass water hose" http://personal.utulsa.edu/~nathan-b...68cylinder.pdf- but I can't figure out where the heck this is located? Anyone happen to have a picture or could describe the location for me?
Thanks very much.
A quick background - just finished replacing my timing belt - reading the previous owners service records they had to have the dealer re-thread #3 spark plug hole - I changed all the plugs as part of my timing belt job, and pulled out the remaining #3 threads in the process - dohh - so - now I get to pull the heads and get an insert put in, and new head gaskets while in there.
BTW - I'm a total 'hack'-yard mechanic with minimal exp. but I figure with the help of this wicked site and the FSM - I should be able to get through this.
Thank again for any help
Steve
Thanks very much.
Steve
Yeah, you'll do fine.
You'd have found the hose when you went to pull the plenum off with it still connected. Here's a couple pics. It's to the right of the throttle body there, in that general area.
the1998sr5
15
07-14-2020 08:35 PM
94 Newbie
08-06-2015 10:33 AM
