Whats a good replacement rear axle shaft?
Old 10-11-2013, 06:39 PM
thenewman's Avatar
1986 4runner
so i broke an axle. going 70 down the interstate. (yeah i know i could hardly believe it could reach 70mph too)
my question is
1.) what is a good place to get a replacement axle shaft? new or used
2.) can i press on my old backing plate, wheel bearing etc. or are there components that i will defin. have to replace to get it put back on correctly
3.) how detailed is this? - any links to similar threads would be great!
thanks!
Old 10-11-2013, 06:47 PM
thenewman's Avatar
....or are there any sellers on here that may have them that anyone has come across?
Old 10-11-2013, 07:23 PM
donomite49's Avatar
You can reuse the backing plate, good time to get new axle bearings and seals on both sides...
Old 10-11-2013, 07:49 PM
thenewman's Avatar
thanks donomite49, i will be sure to get the seals and bearings changed
kinda new question. ive read some conflicting info. want to know what years are interchangeable for the axle shaft on my '86. thanks
Old 10-12-2013, 05:50 AM
RustBucket's Avatar
86-89 is a safe bet. The 84/85 rear axles were a little shorter I think. 90-95 axles may work too, not sure.
You may be able to find someone with an entire axle housing and just pull a side out. Heck, I think I even have one sitting around.
If you do the bearings make sure you have access to a press. I did it without and I would not do that again.
Old 10-12-2013, 07:04 AM
thenewman's Avatar
X2 on the press. I did one myself awhile back and plan on getting a shop to do it this time. Let me know if u have an axle sitting around. I needed one 2 weeks ago. Also in the middle of replacing the trans and almost done. Trying to get my baby on the road. Thanks guys for the help!
Old 10-19-2013, 08:56 AM
NickL's Avatar
Yukon sells shafts with long splines. You take out your old shaft, measure it, and cut the new one to the same length. That way you don't have to worry about getting the right length ordered.
Plus they're a lot stronger than stock too.
Old 10-19-2013, 07:11 PM
RustBucket's Avatar
Pretty sure I've got one but shipping would be a bear.
Old 10-19-2013, 08:03 PM
thenewman's Avatar
I'm interested if u are willing. Just shoot me a price. I would greatly appreciate it!!!
6th Gear
19
12-10-2019 07:31 AM
voiddweller
19
05-02-2016 09:10 PM
DanStew
06-29-2015 10:46 AM
merc1100sc
06-26-2015 05:24 PM
Niameyrider
06-25-2015 05:50 AM
Quick Reply: Whats a good replacement rear axle shaft?
