What would cause pulling and a "hopping" feel?
Old 01-25-2014, 11:31 AM
90YotaPU's Avatar
Randomly my truck starts pulling to the drivers side and starts hopping a little, almost like the tire is really bad out of balance. Yet if I stop or slow down and then speed up, it doesn't do it again. Happens whether going 25 mph or 65 mph. CV axles aren't torn, but I'm wondering if maybe the cold is causing them to bind up. They are at a bit of an angle from the lift. Any thoughts?
Old 01-25-2014, 11:58 AM
90YotaPU's Avatar
Actually, I had a brain fart. Can't be the CVs as I have manual hubs. Must be a brake caliper hanging up.
Old 01-27-2014, 07:34 AM
highonpottery's Avatar
Or bearings, neither of which you want yo seize up while driving. Bearings should be serviced like every 30k or something like that - have yours?
Old 01-27-2014, 08:01 AM
CJM
CJM's Avatar
Check the frontend over. Tie rods, pitman and idler arms, steering box, bearings, shocks, ball joints.
Old 01-27-2014, 08:46 AM
Fossilized
Staff
dropzone's Avatar
Not in 4WD?
Probably a bearing like CJM mentioned
Old 01-27-2014, 10:59 AM
wii_tarded's Avatar
Check your tire as well, had an F-SuperDuty do this several years ago, and turned out to be a broken steel belt in the front tire.
Old 01-27-2014, 11:43 AM
Gamefreakgc's Avatar
If it were a brake caliper still applying pressure you would smell the burning brakes after going 65 MPH if you then examined the vehicle.
I agree with CJM, an extensive visual inspection might reveal a torn boot or something else that's out of place. Grease splatter is also a sign of an issue.
Did you ever have the recall done on your vehicle regarding the steering? I think it was back in 2005...
cars-guy
08-16-2020 06:59 AM
Eggslinger
06-08-2019 03:32 PM
dumpster84
04-30-2016 06:03 AM
smiley52
07-11-2015 05:16 AM
Jnkml
07-06-2015 01:20 PM
Quick Reply: What would cause pulling and a "hopping" feel?
