Weird snapping / knocking
Old 03-20-2010, 04:51 PM
BadMudder!'s Avatar
So let's start from the beginning..
Engines works fine ( 1987 22R )
Engine seizes with an awful squeal revving around 4000 rpm
Engine seems to loosen up and starts again, however with a horrific sounding snapping noise that almost sounds like a knocking in the engine. However I do not believe it is because the sound does not remain consistent when the engine is revved up. At idle, it's constant, but as soon as I rev the engine the snapping noise becomes jumbled and all over the place.
After some research I determine that it is the known issue with the timing guide breaking.
Order ENGNBLDR timing kit. Nice stuff
Remove timing cover to find that the guide WAS broken. Ahaa! that's got to be it. Clean everything up, install all new timing gear.. yada yada yada.
Start engine, and walla!.. noise is still there.
This time, when i drive the truck slowly back and forth in the driveway.. as soon as I get about half gas half clutch, the noise tends to fade or disappear completely. At this point I can slam the clutch in and let off the gas leaving the noise almost non-existent. But, as soon as i try to take off again it's back..
Any ideas? Should I start looking at my clutch/ pressure plate? maybe something in there? I thought for sure it was going to be that timing chain guide.
Old 03-20-2010, 05:03 PM
TOYOTA 1's Avatar
does the engine seize in neutral with the clutch disengaged?
Old 03-20-2010, 05:06 PM
camo31_10.50's Avatar
what does seize mean? i didn't know a motor could just "seize" at 4000 RPM......that's a CRAPLOAD of rotating mass..and it would likely damage something lol
Old 03-20-2010, 05:07 PM
BadMudder!'s Avatar
No, it doesn't. The engine only seized that once. I assume it was the timing chain guide breaking initially.
Old 03-20-2010, 05:09 PM
BadMudder!'s Avatar
okay, I had fixed a bad ground that was causing a stutter, revved the engine up a bit and then I heard a high pitched squeal and the engine had stopped.
Old 03-20-2010, 05:14 PM
TOYOTA 1's Avatar
could be something coming loose in the clutch assembly.
assuming that its not something obvious, i would drop the trans and take a peak.
if nothing looks wrong in there i would drop the oil pan and take a look at the rod bearings.
Old 03-21-2010, 02:26 PM
BadMudder!'s Avatar
Thanks, I plan on checking the trans as soon as possible.
Cheers
Davebarbier
11-03-2015 03:28 PM
moparbay
10-06-2015 09:24 AM
Obmi
10-04-2015 11:30 AM
zombie_barbarossa
10-02-2015 10:54 PM
hiluxinargentina
09-30-2015 05:51 PM
Quick Reply: Weird snapping / knocking
