water pump on 3vze
Old 07-24-2010, 09:43 PM
offroad1990's Avatar
water pump on 3vze
probobly a dumb question but i wana know if i half to take the timing belt off to change the water pump on the 3VZE,, just never done it to mine yet and just wana be sure u kno,, any advice, thanks
Old 07-25-2010, 07:46 AM
Brando338's Avatar
you may as well replace while you're in there. 50-100 bucks.
Old 07-25-2010, 08:43 AM
scope103's Avatar
Yes, the water pump is driven by the timing belt.
And like the man says, don't bother putting the old one back on.
Old 07-25-2010, 09:16 AM
bugs1961's Avatar
You will likely get antifreeze on the timing belt, causing it to weaken and eventually fail. The FSM has cautions not to get any fluids on the belt. I'd change it for sure, and the crank seal while you're in there. I change the cam seals with every belt also--leaking seals can get oil on the timing belt and cause it to break.
thefishguy77
07-30-2015 10:59 AM
Logz808
07-26-2015 07:09 AM
jjrbus
07-19-2015 02:06 PM
Snort
07-19-2015 07:03 AM
Jonny246
07-12-2015 04:51 AM
Quick Reply: water pump on 3vze
