TPS feeler gauge
Old 10-01-2006, 04:05 AM
Yotapup's Avatar
TPS feeler gauge
Where are you guys finding a feeler gauge for the TPS settings? No one around my area has them.Plenty of feeler gauges but none with the particular sizes.
Old 10-01-2006, 04:54 AM
trythis's Avatar
Have you tried NAPA? They have quite a few. I think I stacked some to acheive thh required thickness.
Old 10-01-2006, 05:30 AM
Yotapup's Avatar
Tried NAPA with no luck. I can't even get the right ones to stack and achieve the right size.
Old 10-01-2006, 05:53 AM
bodo's Avatar
If you're only .001 off either way it's not going to matter.
Old 10-01-2006, 06:17 AM
farmerj's Avatar
About it too.
I think I stacked mine to like .557 or something like that and .889. I'd have to dig them out again.
It's a pretty knife edge setting so if you set the off idle first to just cut in, you should right on the closed throttle setting.
Old 10-01-2006, 06:38 AM
Yoda's Avatar
Yup, stacked them to be close to the desired measurement.
Old 10-01-2006, 06:43 AM
Yotapup's Avatar
Alright, thanks guys! I will give it a try.
Old 10-01-2006, 08:04 AM
Fahrenheit 451's Avatar
I bought a cheap set from Harbor freight and as I remember I was able to get spot on for the measurements. Somewhat frustrating locating/handling all those flipping thin ones so I finally just pulled the ones I needed and relocated them at the top so I can always get back to them easily.
Old 10-01-2006, 08:05 AM
I forgot to mention, while you are at it you might as well do the bolt swap on the TPS. It makes it MUCH easier to do when it is still on the truck. There are various posts on here about it and it only costs a couple bucks. I got all the stuff I needed at True Value.
Old 10-01-2006, 04:06 PM
Yotapup's Avatar
Talking
Lucky Me! stopped by Pep Boys and they had an almost perfect feeler gauge that covers all the way up to a 1.00mm gap.
ashamsuddin
17
01-13-2023 03:17 AM
zanzabar0
10-11-2015 02:56 AM
Jdgarrison
10-01-2015 05:22 PM
Rerun
3.4 Swaps
10-01-2015 12:24 PM
dbollier123
09-29-2015 05:23 PM
Quick Reply: TPS feeler gauge
