YotaTech Forums
Go Back   YotaTech Forums > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Sign in using an external account
Register Forgot Password?
Search
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 01-09-2013, 06:16 PM   #1 (permalink)
Personal Sales Rating: (0)
metalhed's Avatar
Switched power
We put some PIAA lights on the truck (1994 pickup) and I am looking for a place to tap into the parking lights and steal some of the power. I would like the lights to only work when the key is on.
Can anyone provide an easy location to tap into the power
thanks
__________________
Metalhed
Rock on Dude!
2001 Red Tacoma, Supercharged, Auto
2" OME lift in front and AAL in the rear
metalhed is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 01-09-2013, 09:38 PM   #2 (permalink)
Chooch's Avatar
Wire it into the fuse box.
Find an accessory or your running lights fuse to tap into.
I see people over complicate these kind of things all the time, easiest and simplest way is to wire it into your fuse box.
__________________
Quote:
Originally Posted by HighLux View Post
If you own a 3.0 I applaud you. You are capable of breaking your own arm to reach impossible bolts, can drive with one eye on the road and one on your temp gauge, and know all the guys at the local parts store by name.
Chooch is offline
Old 01-09-2013, 11:47 PM   #3 (permalink)
Red face
well wiring into the light circuit would turn them on any time the lights are on .
Find a spot in the fuse panel that is energized when the ignition is on then but then unless you instal a switch they are on when the ignition is on.
Bottom line when do you want them to be on.
You can wire them any way you want but if you wire them through the ignition switch to also be powered by the parking light circuit you would need to add a relay
Then the relay coil is powered by the ignition switch when the switch is on the coil pulls the contacts closed that are wired to the parking light circuit and to your new lights. The light come on.
Is this what you want!!!
wyoming9 is offline
Old 01-10-2013, 12:07 AM   #4 (permalink)
RAD4Runner's Avatar
Quote:
Originally Posted by metalhed View Post
I am looking for a place to tap into the parking lights and steal some of the power. I would like the lights to only work when the key is on. Can anyone provide an easy location to tap into the power
thanks
Quote:
By PIAAA, I'm assuming driving lights or fog lights? That will overload your tail light circuit if you stole power from that.
Gotta use relay to handle load current of your PIAA. Supply power directly from battery via inline fuse.
Wire it this way - Using switched ground control, consistent with most Toyota control circuits.
Click the image to open in full size.
If you want it only on only IF ignition is on, take positive power for control (relay coil) from cigarette lighter circuit, since it's already under dash.
IF you wanton only if tail lights are on, tap control wire positive from front marker positive in front corner fender, near marker light. Example of tap on first gen here.
Look at your schematic to verify what color wire to tap from, other wise you could have blinking fog lights
RAD4Runner is offline
Yotatech
4WD Truck
Paid Advertisement
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
Search Engine Friendly URLs by vBSEO 3.5.2
