Swapping Low impedence injectors for High impedence
I am getting a set of High impedence injectors to swap into my 84 celica, same as the 85 22re and other years wiring harness's that uses a resistor solenoid..
So I plan on bypassing the resistor box
So you can run high impedance injectors in place of the low impedance, if you take the resistor block out? I have a good set of high impedance, and would like to run them. I was just unsure what I needed to do if I could run them.
Will that work? According to Toyota, the ECU for high impedance (no resistor box) injectors has a longer pulse time to compensate for the slower speed of the injector. http://www.autoshop101.com/forms/h22.pdf Will the ECU adjust the pulse time for you? Or do you have to modify the ECU?
steve miller
10-10-2015 01:40 AM
