| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
stupid rear window
__________________
currently '89 pickup 4x4 22re extended cab used to have '87 4runner 22re |
#2 (permalink) |
Bump...any ideas?
__________________
#3 (permalink) |
#4 (permalink) |
i know you may have already thought of it but, is it unlocked u know the switch next to it?
__________________
1990 4runner SR5 V6, 3" BL, 2.25" Flowmaster, 33x12.50x15 (current) !998 Honda Civic-Cold air intake, Catback exhaust, Light weight power pulleys, DC headers, short throw shifter, aftermarket spark wires, and plugs (sold) 1995 Buick Skylark (sold) 1991 Mitsubishi Mighty Max (sold) 1957 Ford Fairlane 95% restored (sold) |
#5 (permalink) |
are all your bolts in that hold on your top? I think the 2nd or 3rd bolt from the rear on the drivers side needs to be in for your window to work. (there is a switch under the bolt that the bolt depresses when tightened down) It's to make sure your window wont go back up when the top is off.
__________________
1988 4runner::SAS|3.4L swap|Swap to 5speed manual| RF1A |5.29's|Aussie Front|LockRight Rear|Longfield axles/Hub Gear|4"Rear/3"Front springs|Marlin High Steer|Custom CV rear driveshaft from High Angle Driveline|Rear D/S shortened and made into front D/S |35" Goodyear MT/R | Addicted Offroad front bumper | Marlin rear bumper My 4runner n stuff |
#6 (permalink) |
2nd bolt on the left that holds the top has the switch, according to the manual
#7 (permalink) |
the other option is to take out the switch and clean it, mine was caked with dirt, dried pop etc from the po. the dust that i added from offroading didnt help either!
lee
__________________
93 sr5 v6 auto, 4x4 Photos http://s866.photobucket.com/albums/a...albumview=grid there are quite some attractive ladies on here with Toys. (compliments of ironmike) ifsc 3(.0) http://tlca.org www.of4wd.com www.sontt.com |
#8 (permalink) |
there is also another sensor in the door latch (drivers side i think) that senses whether the tailgate is closed or not. you can fake that one by flipping the latch with a screwdriver, just for testing purposes. mine would work when i flipped the switch, and then not work when i closed the tailgate - problem was that tailgate was not closing all the way due to some weather stripping being in the way.
after you get through that hurdle, there will be another one on the other side. the tailgate/rear window on these trucks is a source of constant misery for some of us. keep in mind that there is also a wire harness clip inside the tailgate. if you ever have a problem where the console switches work, but the tailgate key does not, you will have to check that harness clip for tightness - it has a way of wanting to work apart. i zip tied mine together.
__________________
Yotas I've known... 83 pickup 87 Extracab SR5 4WD pickup 92 4WD pickup 85 long-bed pickup 90 pickup Yotas I own... 00 Extracab SR5 TRD Tacoma (3RZ) **FOR SALE** 85 SR5 4Runner Check the LongBeachRacers, pounding Tacos in the desert! |
#9 (permalink) |
I have an 89 4runner and the same thing happened to me. I replaced all parts, but still the problem stayed around. The problem real problem turned out to be a short in the wiring, so you might have to take the wiring out till you find the short in the line.
#10 (permalink) |
The is a top off switch just behind the driver side rear wheel. There is a door lock detection sensor.
![]() the top off switch breaks ground according to the wiring diagram. It has three connectors. Here is the wiring diagram. ![]() Here's a number diagram for the terminals on the rear window relay. ![]() Apply battery voltage between terminals 1 and 3 of the wire harness side. Check that the window motor turns. Then connect in reverse, check that the motor turns in reverse. This checks out the motor etc. Here's the check list for every terminal on the relay. ![]() door lock detection switch on the driver side. ![]() top off switch
#11 (permalink) |
Mine has a button next to the control youre talking about. Someone has taken it and bypassed it by connecting all of the wires except for the red one. When I wired the button up it wouldnt work so its still bypassed and works fine but I have to use the key.
#12 (permalink) |
btw its the window lock button Im talking about.
#13 (permalink) |
Does the window work when using the key switch in the tailgate? If so, then you have a wiring problem between the console switch and the relay box.
__________________
Gonzo 88 4Runner SR5 V6, 4in lift, 33's, 4.56, TT front, E-locker rear, 4Crawler sliders, custom rear bumper 97 4Runner Limited |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Stupid Theives-Broken Window | PoleVaulter95 | Newbie Tech Section | 20 | 07-08-2007 09:54 PM |
| Stupid, stupid, stupid (I hope I found source of front end noise anyway) | navyredneck | 86-95 Trucks & 4Runners | 1 | 10-28-2006 08:01 PM |
| Another stupid rear window problem | kernel | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 08-21-2005 12:50 AM |
| Solid Rear Window/Sliding Rear Window Trade | MorphiasX | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 11-23-2004 09:18 PM |
| Smoker, vent, stupid small triangle window | phorunninduke | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 03-09-2004 06:29 PM |
