strong exhaust smell?
Old 10-06-2008, 06:45 AM
Endeavor's Avatar
whats going on guys n gals.. here's my question,
i own a 95 Runner with a 3VE 3.slow... i've noticed very strong exhuast smell, more abnormal then before. i've noticed also while i'm in drive(ideling) on the brake i can feel the motor shaking more. now i've just done a tune up, plugs, wires, injector cleaner, oil change.
i can't figure it out?!?
has anyone have any sudgestions?
Old 10-06-2008, 02:00 PM
22RE_yota's Avatar
Not to sound like a dick, but have you popped the hood and done any simple checks like fluid level checks, loose plugs/wires, vaccum hose leaks, electrical connections? or even exhaust leaks?
Is the leak outside the engine bay or inside? (if so..is your fan on vent open?) Have you had any preivious damage wheeling done to the vehicle? Were the injectors sent out to be cleaned or just the fuel additive? If all seems reasonably ok, try jumping you diagnostic terminals and see if any codes come up.
Old 10-06-2008, 06:04 PM
Endeavor's Avatar
i've checked all vacume lines(all seems to be ok) plugs are oem, nice and tight.
haven't done any crazy off-roading. the muffler and piping is only half a year old.
oh i should of added... the smell not getting into the truck. my buddy has the same motor about the same km, and his exhaust fumes are not bad like mine is. i just might change all the vacume line and see what happens. sometimes you can't detect the smallest crack in those black hoses.
i'm going pull the injectors this weekend and see if there gummed up.
thanks for the tips 22RE yota.
step by step i guess..
Old 10-06-2008, 06:31 PM
gtfourdreams's Avatar
hmm.. check your battery terminals. make sure they are not corroded and make sure the wires are in good condition. my 4runner shook and hesitated in the rain when my main ground/negative cable started to corrode.
Old 10-07-2008, 01:49 PM
Endeavor's Avatar
weird that would cause that... i'll check that too
thanks bud.
Old 10-07-2008, 01:57 PM
874runnersr5's Avatar
It could be your o2 sensor, because before i replaced mine it smelt like fuel pretty bad, after i replaced it went away.
just a thought.
Old 10-07-2008, 03:45 PM
Duelertoyota4x4's Avatar
Could be as simple as a small exaust leak at the manifolds or the manifolds them selves.
Old 10-07-2008, 03:46 PM
just a thought.
+1. same on mine too. but i did O2 + new exhaust (cat-back)
Old 10-08-2008, 06:29 PM
Endeavor's Avatar
well i be going through full fall tune up(might as well winter is comming)
i was thinking of changing my O2, cap and rotor, double check all my vacum lines, lube and filter ect.... might as well. also if i have time i want to take out and check the catilitic(spelling)
thanks for all the info guys.
i'll keep ya posted
Old 10-09-2008, 01:29 PM
Endeavor's Avatar
just a thought.
after changed you're o2 sencor, did you get better fuel milage?
Old 10-11-2008, 10:58 AM
jaylor's Avatar
I have the same problem, same year, STRONG exhaust smell, new plugs, wires, o2, cap, no vacuum leaks (that I know of), has check engine light on but don't know what the codes are. I can reset the ECU and it goes away (check engine light) for about 50 miles or so but still acts the same? Also, I have all new exhaust on it as I thought the cat was clogged, no cat now which helped SOME lost power but by no means solved the rough running and exhaust smell. I'm ready to yank it all out and small block it I'm so frustrated!
Thanks.
Old 10-11-2008, 11:12 AM
space-junk's Avatar
um... these trucks require the cats... at least the california trucks do... dont they have a 02 sensors before AND after the cat??
Old 10-11-2008, 11:58 AM
flatland4runner's Avatar
I ahd a similar problem
Turned out to be the TPS. It was relatively cheap part and a real easy r and r.
Old 10-11-2008, 05:24 PM
oooh yeah haha.
Old 10-14-2008, 07:40 PM
jaylor's Avatar
No car "requires" a cat to operate as long as the O2 sensors remain in place. Older style cats provide more harm then good for emmisions in the long run. California vehicles usually have one or two extra "pre-cats" to pass start up emission tests as well as testing under normal operation (full cats) which is also why California cars put less power to the wheels and get worse fuel economy then similer models in other states.
Shaun Crystal Gomban
09-20-2015 11:16 PM
mat
09-17-2015 11:18 PM
larrys93pickup
09-17-2015 07:05 PM
idadan208
09-07-2015 09:06 AM
Quick Reply: strong exhaust smell?
