Stock Exhaust size
Old 05-08-2009, 01:17 PM
tman12345's Avatar
Stock Exhaust size
What is the size of the piping going between the cat and muffler
Old 05-09-2009, 11:19 AM
isaac338's Avatar
If you call a parts place and get them to look up the part number for an exhaust clamp for your truck, that's an easy way to tell.
Old 05-09-2009, 11:25 AM
abecedarian's Avatar
IIRC, the stock is 1 7/8".
Old 05-09-2009, 12:36 PM
tman12345's Avatar
so if i were to order a new aftermarket muffler would i order it with a 1 7/8 inlet or bigger so the echaust slips into the inlet?
Old 05-09-2009, 12:38 PM
yoterr's Avatar
if you order a muffler for an 1" 7/8's it should be flared on each end to slide over the exhaust....i think
Old 05-09-2009, 12:39 PM
Jay351's Avatar
Thats for the 22re.. 3vze is 2 1/8th fyi....
Is this something you're doing yourself?
Old 05-09-2009, 07:01 PM
tman12345's Avatar
yeah i'm replacing the muffler and tail pipe, but not with a stock muffler.
Old 05-09-2009, 07:06 PM
ozziesironmanoffroad's Avatar
Test pipe it!!!
Old 05-09-2009, 07:10 PM
tman12345's Avatar
Originally Posted by ozziesironmanoffroad
Test pipe it!!!
what do you mean?
Old 05-09-2009, 07:12 PM
scuba's Avatar
He probably meant test fit..
Old 05-09-2009, 07:16 PM
tman12345's Avatar
well i'm not sure but to me it looks like the tailpipe is a different size than the pipe leading up to the muffler so i couldn't really test that without cutting it. but then again i'm sure if they are actually different sized.
Old 05-09-2009, 08:22 PM
waskillywabbit's Avatar
Measure circumference divide by PI.
Old 05-09-2009, 08:32 PM
no by test pipe i mean removing the cat and putting a tube (called a test pipe) in place of the cat, then running to your muffler. sounds mean as heck. ... not healthy to the environment though. hence, the 'test pipe' meaning its not permanent. (or is it...?)
Old 05-10-2009, 10:15 AM
tman12345's Avatar
ha, i completely forgot about all those days of math schooling, thanks for the idea.
as much as i'd like to do that, i feel like it would take to much effort, and i won't be able to pass MA inspection if i left it like that.
RatOmeter
10-22-2015 03:17 PM
tj884Rdlx
08-28-2015 12:04 PM
justdifferentials
Just Differentials
08-15-2015 05:25 PM
coffey50
07-28-2015 10:55 AM
Gravel Maker
RuffStuff
07-27-2015 06:53 PM
Quick Reply: Stock Exhaust size
