squeeky turning
Old 07-04-2007, 11:32 AM
yota_dude's Avatar
squeeky turning
i need help greasing these but dont know how to. it is really starting to bug me. and my clutch also squeeks when i push it in is there anything i can do to fix them.
Old 07-04-2007, 12:42 PM
BeaterToyota's Avatar
Are you sure that's where it's squeaking? It looks like you're pointing to the pitman arm/steering box, and there really isn't anything to lube.
These steering stops are usually where a lot of squeaking/grinding come from. just slather some grease where you see the arrows. Do this on the passenger side and driver side, and do the stops on the front and the back of the steering knuckle.
Old 07-04-2007, 01:42 PM
91TPU's Avatar
i agree with the above, it happens at full lock
also my clutch is a little squeaky too, i hear its something that most older yotas do.
Old 07-04-2007, 08:37 PM
bigtrucknwheels's Avatar
Location: Where it always works if you work it, in Sunny Selinsgrove, PA
Also consider that the torsion bars love to creak and squeak very much when the wheel is turned all the way to a side and you travel over any kind of a difference in height. Sounds like the damn truck is falling apart.
Old 07-04-2007, 08:43 PM
91TPU's Avatar
sounds more like steering stops to me....
Old 07-05-2007, 05:19 AM
Yeah i oughta grease mine up and see what difference it makes for me. That sound not only drives me nuts but it is also semi embarrassing when your showing someone your truck.
Old 07-05-2007, 05:25 AM
CanTheWhales's Avatar
squeaky clutch pedal or clutch itself...? it's been talked about before how the return spring on the pedal can be oiled to alleviate squeaks.... also, don't just grease anything steering related... start with the stops as above mentioned and see if that works.
Old 07-05-2007, 11:44 AM
Jay351's Avatar
squeaky clutch pedal is very common with these trucks, its kinda funny
Old 07-06-2007, 06:34 PM
943kgt's Avatar
easy fix for that is peel the clutch fork boot back and spray some white lithium in
Old 07-08-2007, 12:36 AM
stormin94's Avatar
My advice:
GET USED TO IT. Every Toyota I've ever driven has some sort of wierd squeak or rattle to it. It adds character. If you see an IFS yota making a U-Turn, then you will hear it squeak, or rattle. I've grown to like my squeaks. If they stop, or get louder, that means that something's not right. Your truck is talking to you.
okamikai
04-30-2018 10:19 PM
Shoua
13
05-22-2016 05:19 AM
Dakotaneu
08-15-2015 07:24 AM
JHalcyonM
08-04-2015 01:19 PM
Hamonacracker
07-17-2015 08:33 AM
Quick Reply: squeeky turning
