Speaker ideas for regular cabs???
Old 06-06-2006, 11:16 AM
Saint_Berzerker's Avatar
Wondering if anyone has any ideas for some good sound. I bought some Infinity 4" for the under dash, and I got some 6x9's for behind the seat, but the 6x9's sound muffled from being back there, I guess.
I can't really think of anything else. I wanted to put some in the kick panels but the dang ecu is on the right one and there's no room.
Would putting them in boxes help? Or whatever anybody can think of....
thanks
Old 06-06-2006, 12:28 PM
TNRabbit's Avatar
There is a company called QLogic that makes custom kick panels that will clear the ECU, etc. Website: http://www.qlogic.ws/2003/home/
Old 06-06-2006, 02:25 PM
Elton's Avatar
i had 6-1/2'' 3 ways in the doors and a 8'' sub behide the seat it sounded good for a reg cab
Old 06-06-2006, 07:58 PM
geez....how deep do the doors go? Doesn't look like there's much room behind the door panels.
Yeah, I've seen the qlogic kickers...might check them out for some more front speakers.
Just trying to figure out something for the 6x9's.
Old 06-06-2006, 08:02 PM
Elton's Avatar
i made 1'' spacers for the doors also you can make 6x9s fit in the doors
Old 06-07-2006, 08:56 AM
Bobakazi's Avatar
I go with a 2-way component set up front. Get a good brand (I love MB Quart), and mount the 6 1/2 speaker down low in the door and the tweeter close to the window. Quart sell extension rings so that the depth of the speaker will fit in the door. For me, they were a bit of a pain in the butt to install because you have to find a good location for the x-over. I mounted mine inside the door. After it was done though, it was WELL worth it.
Old 06-07-2006, 09:00 AM
Sonofmayhem's Avatar
my dad mounted some on the roof, behind the head rest and it sure did blast your ear, i have some xplods in my kick panels and they are LOUD! im gonna be putting 6x9s in the rear of my runner and then a sub to thump that glass. lol
Old 06-07-2006, 09:28 AM
TNRabbit's Avatar
Here's another great side for odds & ends, patch cables, speaker adapters, etc.:
http://www.installer.com/speakerparts/index.html
Old 06-07-2006, 04:23 PM
Spanky's Avatar
i have the same damn problem.... new pioneer 4" up front and matching 6x9"s in seperate boxes behind my seat. The rears sound muffled, or kinda seem to resonate alot. dont know if its the speakers, or it being being the seat causing it. either way i want 4 new speakers cause i am really disappointed with the pioneers.
i also really want a subwoofer! i bought two 6 1/2" subs to put inbetween the 6x9s and they did not play low like a actuall sub at all.
installing seperates crossed my mind. installing a custom made box that will hold a 10"
sub, amp and the two 6x9"s also crossed my mind but those two cost a lot of money i would rather spen on other stuff. so who knows what i will do.
Old 06-08-2006, 03:10 PM
surf4runner's Avatar
i put 4" pyles in the dash and 1" tweeters on the door. 2way 6X9 behind the seat for the low end (w/band pass filters), doesnt sound muffled
Old 06-08-2006, 09:30 PM
Bobakazi's Avatar
Anything behind a seat is going to sound muffled. Period. Raw bass will do much better than highs. Put your tweeters somewhere pointing towards your face, and your mids in your doors. If you want/need a sub, get a high powered amp and locate it behind your seat in a truck box.
Old 06-08-2006, 09:37 PM
Brendan's Avatar
Infinity Reference 6000cs components in the doors and a JL Audio 10w0 behind the passenger seat. MTX 4 channel amp under the driver's seat. Sounds good!
Old 06-09-2006, 07:20 AM
kyle_22r's Avatar
i've got treo 4" speakers in the dash(what a PITA, they hardly fit) and they sound just plain awesome for a 4" speaker. i'd like to get some 6x9s or something behind the seats to add some bass, though.
Old 06-09-2006, 09:44 AM
newhorizons's Avatar
speaker idea's
i just ran a box of (2) two 6 by 9's in through my pioneer..move it around.have a tight bungee cord attached to the stock tie downs..simple..like me..
Old 06-09-2006, 10:11 AM
Avsfreak1234's Avatar
lots of good ideas. I dont know much about the door speakers but I recomend a bazooka for bass behind the seat. Iv been doing a lot of shopping for my taco and the Bazookas are not the most powerful but they make the best quality sound
Old 06-09-2006, 10:27 AM
89red4x4yota's Avatar
i have 4 inch infinities in my dash and two 8 inch subs behind my seat, and up in the back corners were the seatbelt buckle sits when you are not using it, i have two tweeters on each side so 4 total. sounds pretty good
Old 06-09-2006, 01:10 PM
-MaTTi-'s Avatar
I think itīs same thing to do than at 4Runner.
Originally Posted by -MaTTi-
This is what I made at last summer:
I made about 1 cm (―") plywood spacer between speaker (5.25") and kick panel and coated them by gray felt. There is not much space between window frame and panel, maybe 4-5 cm (<2"). I screwed screws (x4) through the spacer and panel to the door plate. The location of the speaker is what is it (quite low) because of the door opening limit rain (or what is it, I donīt know the name ) . I managed to thread wires through the rubber between door and frame, it was painful/difficult (there is 23 wire if I remember right).
Maybe this could help to compose the image of situation:
I have treble speakers on A-pillars also.
Old 06-09-2006, 05:15 PM
vmax84's Avatar
Well, you could always make a whole lot of work out of it!
Check this mess out.
http://community.webshots.com/myphot...ecurity=xzfUYN
vmax84
coreyedwards7611
01-16-2016 06:38 PM
88sasturbotoy
08-11-2015 01:56 AM
DrZero
18
07-24-2015 11:31 PM
Fundy Rider
07-16-2015 01:35 AM
Seattle_Sign_Guy
07-12-2015 12:38 PM
Quick Reply: Speaker ideas for regular cabs???
