Spartan locker not disengaging! please help
Old 10-02-2010, 09:14 PM
VANCE164's Avatar
So I've been searching for the last few days and can't find any awnsers. So to the question.
The other day we installed a spartan locker into the front end my buddys samurai ( I know It's a Toyota site but alot of you are very knowledgeable and figured you could help) we falled the terrible instructions to a T. When we installed the third member back into the axle and went for a drive it was popping very loudly and was unturnable in 4wd. and it would not unlock aso we spun the tires first to lock it but could not get it to unlock any ideas here? please help
link to instructions these are the same but better picture quality then it came with! in fact you cant see the pictures in the manual!
http://www.ringpinion.com/Content/Ho...structions.pdf
thanks in advance!!
Old 10-02-2010, 09:50 PM
BigBluePile's Avatar
Were you applying power thru the turn? Was the "drive" on the pavement?
Old 10-02-2010, 09:58 PM
VANCE164's Avatar
it was on pavement but the popping was extremly loud like it was breaking something it could be heard from 2 blocks away! but pulled it back out and everything looked fine... but in the instructions it says with it in the air you should be able to lock and unlock it by spinning the tires.
Old 10-02-2010, 10:06 PM
Yeah I think it says something like spin tires in opposite directions or something. I know after I installed mine, I ran the front end thru pretty thoroughly on the jack stands. I haven't field tested it yet. The locker doesn't disengage. It ratchets under "no load" conditions like coasting thru turns.
Old 10-02-2010, 10:09 PM
99blackSE's Avatar
Hmm, sounds like the springs aren't de-compressing off load causing it to be locked up all the time...
Old 10-02-2010, 10:10 PM
VANCE164's Avatar
It just doesnt seem right i talked with others who have lockrights up front and they say the steering isnt that much different or terrible but its like his isnt un locking and is like worse then haveing no power steering!
Old 10-02-2010, 10:11 PM
VANCE164's Avatar
Is their anyway to fix this?
Old 10-02-2010, 11:07 PM
Bugzman's Avatar
I have an aussie up front and it did the same thing to me on pavement. Under any load it will not unlock. try locking the hubs but leaving it in 2wd. this will never put any load on the carrier and you should be able to drive it fine on pavement. just will some general clicking.
Off road it is much easier to turn while locked because the tires just slide on the dirt.
Old 10-03-2010, 01:37 AM
VANCE164's Avatar
yea i just think their something else going on and i dont want him to break a locker or ring gear or pinnion!
Old 10-03-2010, 09:17 AM
scuba's Avatar
Did you do the spin test?
Also, you should never drive in 4wd on pavement. Especially with the locker in there. Take it to a gravel lot or something next time.
Old 10-03-2010, 10:02 AM
camo31_10.50's Avatar
Scuba is correct.
it sounds like ya'll are applying power (read as; giving it gas) that will cause it to stay locked.
try going around a corner COASTING..that means no power will be going to the axles and you should be just fine.
Old 10-03-2010, 10:50 AM
VANCE164's Avatar
when we did the spin test we could not get it to unlock
Old 10-03-2010, 11:13 AM
dark_fairytales's Avatar
if you have it jacked up on stands and can not get the tires to spin in opposite directions with a clicking sound. you have something wrong inside. it should be fairly easy to get the lockers teeth to sleep by each other.
as stated before. if there is any sort of torq. going down the front d-shaft, the locker will not unlock.
Old 10-04-2010, 12:15 AM
81redbluffyota's Avatar
Location: I live in Red Bluff ca. Right by the Sacramento river
Im very confused on this, as I though a spartan was the same as an aussie, just a simpler install. If this is the case, then NO, you wont be able to jack the truck up, and spin the tires in opposite dircetions. A lunchboc locker works like a ratchet wrench. One trie can travel FASTER than the ring gear, but not slower, or in the other direction. As far as in locking and unlocking. Thats the nature of a drop in locker. My aussie would pop no matter what, on gas or off. Would get real weird if u were in a trun with clutch out, and pushed it in while you were in the tunr. Alot of the popping, and unloading noises are goin to be dependent on how close to spec your side wahsers were when you put them in.
Old 10-04-2010, 12:37 AM
VANCE164's Avatar
well crap everyone says something different lol its all so confusing and I feel bad for my buddy hes getting so upset hopefully the folks at spartan can help him out tomorrow!
Old 11-10-2010, 12:15 PM
drkblu4runner's Avatar
i got the same prob in my 94 4runner i have an ez locker tho.... when i do spin test the tire doesnt move at all. i drove on pavement and i cant turn at all. good thing i got an extra cv, im going to need it.
still dont know why tho?
TheBFA
02-15-2020 06:55 AM
83yotastockR
11
11-10-2015 06:54 AM
Toys4parts
09-26-2015 01:56 PM
toyotasaurus
09-24-2015 03:30 PM
zz_denis
09-06-2015 03:43 PM
Quick Reply: Spartan locker not disengaging! please help
