Spartan locker not disengaging! please help
So I've been searching for the last few days and can't find any awnsers. So to the question.
The other day we installed a spartan locker into the front end my buddys samurai ( I know It's a Toyota site but alot of you are very knowledgeable and figured you could help) we falled the terrible instructions to a T. When we installed the third member back into the axle and went for a drive it was popping very loudly and was unturnable in 4wd. and it would not unlock aso we spun the tires first to lock it but could not get it to unlock any ideas here? please help
link to instructions these are the same but better picture quality then it came with! in fact you cant see the pictures in the manual!
http://www.ringpinion.com/Content/Ho...structions.pdf
thanks in advance!!
thanks in advance!!
it was on pavement but the popping was extremly loud like it was breaking something it could be heard from 2 blocks away! but pulled it back out and everything looked fine... but in the instructions it says with it in the air you should be able to lock and unlock it by spinning the tires.
Yeah I think it says something like spin tires in opposite directions or something. I know after I installed mine, I ran the front end thru pretty thoroughly on the jack stands. I haven't field tested it yet. The locker doesn't disengage. It ratchets under "no load" conditions like coasting thru turns.
It just doesnt seem right i talked with others who have lockrights up front and they say the steering isnt that much different or terrible but its like his isnt un locking and is like worse then haveing no power steering!
Off road it is much easier to turn while locked because the tires just slide on the dirt.
Scuba is correct.
it sounds like ya'll are applying power (read as; giving it gas) that will cause it to stay locked.
try going around a corner COASTING..that means no power will be going to the axles and you should be just fine.
if you have it jacked up on stands and can not get the tires to spin in opposite directions with a clicking sound. you have something wrong inside. it should be fairly easy to get the lockers teeth to sleep by each other.
as stated before. if there is any sort of torq. going down the front d-shaft, the locker will not unlock.
From: I live in Red Bluff ca. Right by the Sacramento river
Im very confused on this, as I though a spartan was the same as an aussie, just a simpler install. If this is the case, then NO, you wont be able to jack the truck up, and spin the tires in opposite dircetions. A lunchboc locker works like a ratchet wrench. One trie can travel FASTER than the ring gear, but not slower, or in the other direction. As far as in locking and unlocking. Thats the nature of a drop in locker. My aussie would pop no matter what, on gas or off. Would get real weird if u were in a trun with clutch out, and pushed it in while you were in the tunr. Alot of the popping, and unloading noises are goin to be dependent on how close to spec your side wahsers were when you put them in.
i got the same prob in my 94 4runner i have an ez locker tho.... when i do spin test the tire doesnt move at all. i drove on pavement and i cant turn at all. good thing i got an extra cv, im going to need it.
still dont know why tho?
TheBFA
Feb 15, 2020 06:55 AM
83yotastockR
11
Nov 10, 2015 06:54 AM
Toys4parts
Sep 26, 2015 01:56 PM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
Sep 24, 2015 03:30 PM
zz_denis
Sep 6, 2015 03:43 PM
