Sloppy front end drive shaft
Old 07-22-2009, 09:54 AM
Lifelongtoy's Avatar
Question Sloppy front end drive shaft
Anyoone know where I can find a new or rebuilt front propellor shaft? I'm looking to replace the whole assembly.
Old 07-22-2009, 09:59 AM
4Crawler's Avatar
What is worn, u-joint, CV joint, slip yoke?
Check out a local driveline shop, they can usually do the rebuild.
Old 07-22-2009, 10:28 AM
This may sound weird but whats worn appears to a little ball in the middle of what I think is the cardan jiont. Before I remove the shaft, the slop seemed to come from that ball. Any thoughts?
Old 07-22-2009, 11:07 AM
4Crawler's Avatar
Should be able to rebuild the CV joint, or else pick up a front shaft from most any '86-'95 4WD truck and swap that part out.
bigjstang
08-25-2021 12:41 AM
06-01-2021 01:51 PM
Jnkml
07-06-2015 01:20 PM
Vargntucson
07-04-2015 12:15 PM
TNRunner88
07-01-2015 08:00 PM
Quick Reply: Sloppy front end drive shaft
