Rear Wiper Refill - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 12-08-2008, 05:54 PM   #1 (permalink)
TOOLMAN's Avatar
Rear Wiper Refill
Does anyone have any idea where to get rear wiper refills? I've been searching for about a month now and can't find anything.
It seems as if auto parts stores don't even stock 'refills' anymore. Is there an adapter you can get to update it?
__________________
-TOOL
_____________________________________________
'93 4Runner 3.Slow, Automatic, 31" BFG AT's , Leather & Sunroof
'71 1/2 Bronco 302, NP435, 3" WH Lift w/ 11 pack rears, 33" BFG MT's
TOOLMAN is offline
Old 12-08-2008, 05:56 PM   #2 (permalink)
littlecommando's Avatar
Send a message via AIM to littlecommando
if i were you, i would just take them off, the rear wipers dont do anything.
__________________
1985 Toyota 4Runner SR5 4WD red, mostly stock, mossy oak seat covers, custom stereo system, Dixie Horn, Custom Rear Bumper
Build Up
Powder Springs, Georgia
Quote:
Originally Posted by Corey View Post
Once must also realize that YotaTech has always been open to both 2WD and 4WD trucks and SUVs.
This means the gnarliest off road rig, to the lowrider that scrapes its belly over a dime in a parking lot.
While it is true that 4WDs far outnumber the 2WDs here, all are welcome.
littlecommando is offline
Old 12-08-2008, 06:10 PM   #3 (permalink)
myyota's Avatar
I got one from www.autopartswarehouse.com
myyota is offline
Old 12-08-2008, 09:37 PM   #4 (permalink)
I ordered one from my local dealer... was only like $10 or so.
khany2002 is offline
Old 12-08-2008, 09:39 PM   #5 (permalink)
leebee's Avatar
walmart has replacement blades and so should just about any auto supply shop. just check the flip book listing section for truck/suv.
lee
__________________
93 sr5 v6 auto, 4x4
Photos http://s866.photobucket.com/albums/a...albumview=grid
there are quite some attractive ladies on here with Toys. (compliments of ironmike)
ifsc 3(.0)
http://tlca.org
www.of4wd.com
www.sontt.com
leebee is offline
Old 12-08-2008, 09:40 PM   #6 (permalink)
4runnermt's Avatar
I bought a refill for a 3rd gen 4runner and had to cut an inch or so off it. Works like a champ and was like three bucks.
4runnermt is offline
Old 12-08-2008, 09:54 PM   #7 (permalink)
Tubbyfatty's Avatar
Send a message via AIM to Tubbyfatty
Quote:
lee
or go up to the counter and they will tell you the size. Just make sure you are looking at the screen with them so they dont tell you the wrong length. Its happened so many times.
__________________
94 4runner / SR5 / 3vz-e / 5spd / 4x4 (duh) / Mudcat EXT 30x 9.5R15s / Marlin Crawler HD Clutch / ISR / Hella 700FFs 100w bulbs / 2 10'' JBL subs / ported sub box / kicker mono amp / Pioneer DEH-P490IB / sitting 1-1.5'' below factory, thanks butt sag...
Tubbyfatty is offline
Old 12-08-2008, 10:01 PM   #8 (permalink)
Matt16's Avatar
Quote:
Uh, if you turn it on it does. The back of the truck gets covered with mud, dust and water if you drive in the rain or off paved road.
__________________
1990 Toyota 4Runner 22RE 5spd
*Aussie Locker*York OBA*
Quote:
Originally Posted by DaveInDenver View Post
Yeah, I do think it's sort of funny. Can't you see a roomful of Toyota engineers looking at a relay rod, scratching their heads and saying 'Hmmm, this part wore out after 200,000 miles and 16 years, this is just unacceptable.'
Quote:
Originally Posted by DeathCougar View Post
next time when the front of your engine sounds like a can of spoons, fix it
Toyota FAQ link
More info on 4Runners
Matt16 is offline
Old 12-08-2008, 10:24 PM   #9 (permalink)
HupDogDaddy's Avatar
I have a 95 4skinner and I just replaced mine with a cheapo Pylon brand from WalMart--- I got the 14".
you will need to use the angle adaptor that is supplied with it. You will also have to ditch the stob that rides up the parking ramp.
__________________
"Everyone should believe in something -- I believe I'll go hunting!"
HupDogDaddy is offline
Old 12-09-2008, 08:02 AM   #10 (permalink)
On my 95: Buy a 14" wiper arm at WalMart for about $4. If you can find a 14" blade somewhere, you can use that. Cut the factory blade out of the rear wiper arm(it's made so it can't be removed). Take the 14" blade out of the cheapo arm and slide it in from the bottom of the rear arm. When you push it in, you'll find the final "loop" on the rear arm is too small for the replacement blade to fit through. Use needle nose pliers and widen the opening so you can push the refill blade in and lock it.
If you remove the rear wiper locking/holding mechanism, you may find that you can't operate the rear window.
__________________
WatermanAtWork - 1995 4Runner SR5 - 1990 Pickup
GorgeRunner is offline
Old 12-09-2008, 09:56 AM   #11 (permalink)
Quote:
not sure about your 4runner, but mine has a vertical back window, so watter just falls off it, and i have not managed to get mud on my rear windshield.
__________________
Build Up
Old 12-09-2008, 10:24 AM   #12 (permalink)
blacklabel's Avatar
I just orderd a new rear wiper blade/bracket/rubber for $14 CDN from the Toyota Dealership yesterday.
may be a little pricey, but everything replace on my truck I try to get at LEAST OEM quality
__________________
'05 4Runner SportEdition V8 auto
'92 4Runner SR5 2-door V6 5sp
'01 Honda S2000 roadster 6sp (sold)
'89 Mazda RX7 turboII convertable (sold)
'86 Toyota 4Runner 22re 5sp (sold)
blacklabel is offline
Old 12-09-2008, 10:33 AM   #13 (permalink)
4Crawler's Avatar
On my '85, I just picked up a blade refill of the approximate length of the stock blade and slid it into the wiper arm. Worked fine.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 12-09-2008, 01:23 PM   #14 (permalink)
T-1000's Avatar
My rear wiper blade is hand cranked now...
__________________
'90 4Runner SR5 V6 Automatic, pretty much stock.
I don't have a T100, my name is a reference the bad guy in Terminator 2.
Quote:
Originally Posted by NorCrawler View Post
well its my truck i can have whatever interior i want, and what if i dont change it, you gonna pull me over for PIMP interior? jealously thats all.
T-1000 is offline
Old 12-09-2008, 02:02 PM   #15 (permalink)
Matt16's Avatar
I don't have a picture of my truck, but here's one of a vehicle I saw in Alaska.
__________________
Toyota FAQ link
Matt16 is offline
Old 12-10-2008, 07:40 AM   #16 (permalink)
the ones made for beamers have an adaptor to be used, also if you go to a yota dealer, they may have one, that is where I got my last one.
rangerruck is offline
Old 12-11-2008, 08:27 AM   #17 (permalink)
4mydogs's Avatar
"I WISH MY GIRL WAS THIS DIRTY"
__________________
1995 SR5 V-6 4WD Limited, 180k miles, 31X10.5 BFG All Terrain T/A KOs, Downey 1.5HD rear coils, 9" Doetsch MV-12s, Hella 1000 fog lights, Alpine XM/CD head unit, and rear window dog drool.
That which you manifest is before you.
-- Enzo
4mydogs is offline
Old 12-11-2008, 09:32 AM   #18 (permalink)
Tubbyfatty's Avatar
On my runner ive got an air dam thing on the back by the 3rd brake light, isnt that to keep dust and such off the back end? I havent noticed since its been raining here for a while now, and i dont go on dirt roads that much.
__________________
Old 12-15-2008, 02:52 PM   #19 (permalink)
TOOLMAN's Avatar
Thanks for all the ideas fellas. I went the 'buy the whole blade and take the rubber out of it' route like GorgeRunner suggested. Only time will tell if it works. It's too cold here to get the back window wet. The high for today was like 5 or so.
__________________
-TOOL
TOOLMAN is offline
Old 01-28-2009, 03:42 PM   #20 (permalink)
OK, here's what I did.
By the way, those who say you just go to walmart or autopartswarehouse (you get no results when searching rear wiper for Toyota 4runners) must not be paying attention, or else have a different wiper. There are none out there like this one, that I could find.
The arm is not replaceable with standard arms out there even with adapters that I can see. It is held by two screws along with an opposing knob that stabilizes the arm. Mine works from the top. So you unscrew it and off comes the arm with a bracket - no unsnapping possible that I can see.
So, pretty much as GorgeRunner said: I bought a 14in replacement arm, and worked it a bit. The blade that was in it did not want to be removed (I should say rubber blade and metal blade supports). So i had to cut it apart to remove it. The replacement I bought, however, was removeable - with a bit of effort. There is one narrow blade holder where the metal blade supports protrude to prevent it from sliding. Squeeze the protrusions of metal together and it will slide off (Kind of tricky to do). Once off, it will slide back onto the original blade holder - just remember to put those protrusions on the 'narrow' blade holder (slide the blade towards this narrow holder end through all the wider holders first). It slides then snaps right on.
loki is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Rear wiper kawicowboy 95.5-2004 Tacomas & 96-2002 4Runners 7 11-28-2008 10:40 AM
Rear window and rear wiper dead. Uncle Meat 95.5-2004 Tacomas & 96-2002 4Runners 8 08-18-2008 07:10 PM
Rear wiper fishon1213 General Electrical & Lighting Related Topics 3 04-27-2008 08:31 PM
2003 rear defrost & rear wiper micg1313 03+ 4Runner/GX470, & 05+ Tacomas 3 03-19-2007 04:12 PM
Rear Wiper clint 86-95 Trucks & 4Runners 4 06-12-2006 08:33 AM
2009 InternetBrands, Inc.
