Quick axle question !!
Old 09-04-2013, 01:21 PM
Yodalife12's Avatar
Looking to do 529s front and rear have a 93 pickup with 93 rear axle and 84 solid front are the gears and the bearings an seals all the same ?
Old 09-04-2013, 03:39 PM
MudHippy's Avatar
Quick axle answer !!
No, they are not. The bearings and the housings(3rd members) are different.
Sorta complicated to explain how. So read this post instead http://www.pirate4x4.com/forum/1478223-post73.html
Old 09-04-2013, 07:51 PM
Yodalife12's Avatar
Ok thanks !
Old 09-04-2013, 08:12 PM
Redeth005's Avatar
If you're IFS up front your front 3rd needs to be 7.5" not 8" like a SFA 3rd.
Old 09-05-2013, 03:48 AM
Yodalife12's Avatar
I did a SAS seap im straight axle. They a re both 8" axles right ?
Old 09-05-2013, 04:16 AM
Yodalife12's Avatar
Old 09-05-2013, 04:54 AM
Redeth005's Avatar
If you used a toyota front axle then yes they are both 8" axles.
I used an 85 toyota pick up axle. and i ordered 2 sets of 4.88 gears and 2 sets of spartan lockers. The only difference that you need to look out for is the size of the 3rds. My truck has a V6 and has the beefier 3rd member. The front axle was off of a 4cyl so it has a smaller 3rd. NOt too much because its still an 8" housing like the V6. But I'm just saying if you plan to buy or order some parts, make sure you have that specified first.
Only way this is exempt is if you put in a a v6 3rd into the 4cyl axle housing.
Hope i didnt confuse you. Like i said you should have 2 8" 3rds if you used a front toyota axle. just specify whether its a 4cyl or v6. and you'll be fine.
Old 09-06-2013, 07:47 AM
Yodalife12's Avatar
http://item.mobileweb.ebay.com/viewi...d=330846976072
My front is a 84 4cyl toyota soild axle
My rear is the factory 4cyl housing and 3rd so this set up above should work fine right ?
Old 09-06-2013, 08:00 AM
Redeth005's Avatar
Perfect. That will fit perfectly.
Old 09-06-2013, 09:21 AM
Yodalife12's Avatar
Sweet thanks for te help and info !
oldirtydirt
02-23-2020 09:30 AM
jasonty
41
12-23-2018 01:00 PM
Nailit69
Diesel Swaps
07-21-2015 05:28 PM
yourrealdad
07-21-2015 11:13 AM
icentropy
07-14-2015 10:23 AM
Quick Reply: Quick axle question !!
