Please help! Running rich
Maybe one day my runner won't have any problems but today's not that day. Leaving camping on sunday I start my truck and it dies instantly does this a few times then I start it and give it gas get it warmed and it idles low(500) and seems to bounce up a few hundred rpms I have black smoke coming from the exhaust with a horrible smell. When I drive it it feels like it has no power and wants to buck at low rpms. Replaced the air filter, didn't help but thought I should try since there was tons of dust while driving around where I was at and my filter was really dirty. Any ideas before I decided to buy something new
yes
that will help. pound on it with your fist hard and listen for loose material bouncing around in there. pull it out and gut it. then put it back on and forget about it. exhaust will be louder, but who cares? run it hard.
hate to say but my wife has the same truck color and every thing. Look toward the afm and tps b4 ya put a 60 plus labor cat on it they are nutten but a heating element to burn off stuff a good worken motor will
3.0 is like a fatty that got skinny got work for it if ya want it good wait ok motor when it works but if ya can get all the chipmuks to work together it is a good tar car motor
are all your plugs seated? you hitting on all cylinders? check all the simple stuff. if you drove it in there and it was working fine, maybe you just jarred something loose... i dont know.
Yea I keep checking everything today i unplugged the egr it drove better but still black smoke but the bucking has gone away and I still have a low idle I've also noticed if I remove the brake booster hose my idle goes up to where it should be. Nothing is adding up
New symptoms I replaced the o2 sensor still no fix thinking maybe it was my vfam so I drove it to my friends a block away and halfway there it started running real bad no power when I hit the gas it was like nothing happened then it started backfiring got to his house put his vfam on and started it it idled high about 1200 but sounded a lot better not like it did before no loping sound then after about 45 seconds it would drop down and die. So I'm thinking it could be the vfam as well as something else? Any ideas
coffey50
07-28-2015 10:55 AM
