Painting my Canopy???
Old 03-12-2009, 02:59 PM
pathfinder's Avatar
Hey guys, picked up a cheap canopy for my rig. The truck is red and the canopy is faded blue which isn't gonna work for me. Should I get it painted red or attempt it myself? I could probably live with a black canopy as well. Suggestions?
Old 03-12-2009, 03:22 PM
Junkers88's Avatar
Grab some 1500 grit sand paper and sand the heck out of it. Once you get the surface roughed up a bit go grab some primer in cans (black or grey) and shoot it. Then later on if you want to try and paint it yourself you already have a good primer base. Just be aware that matching a faded factory paint color is really hard unless you know what you're doing.
I'd say shoot it black and leave it.
Old 03-12-2009, 03:27 PM
scuba's Avatar
What ricky said !!
Painting isnt hard, just takes a little common sense and patience...
Old 03-12-2009, 03:30 PM
randito's Avatar
I painted mine white and think it looks good with the red truck and black wheels
Old 03-12-2009, 03:45 PM
iamsuperbleeder's Avatar
just remember, every good paint job starts with good preperation
don't just grab some spray paint and go at it, do like Junkers said; sand it, prime it, and paint it; maybe even clear coat it for protection
Old 03-12-2009, 05:54 PM
StangBanger's Avatar
I say you prep it right and try to match it to your truck..and if you can't then stop being lazy and try painting the truck again. I'm sure with some common knowledge and a long weekend and a garage or one of those parking tents (basically to try and keep the truck away from outdoor elements..wind,dust, dirt etc) you could do a pretty good job on your truck.. Rent an air compressor from homedepot or some hardware store and buy yourself a spray gun from harborfreighttools.com and you should get great results for minimal money loss.. But if you want a quick fix then I suggest you just sand it down properly and give it at least 2 good coats of black primer. Good luck and feel free to take some pics of your project. I know I'm interested in the outcome.
Old 03-12-2009, 08:35 PM
RocknRon206's Avatar
I scotched brite my canopy and picked up some Gloss Rustoleum red and black in the 1 quart can, then added black to the red a little at a time till I was satisfied with the color, thinned it out a bit and sprayed it with an HVLP gun. It came out pretty good.
https://www.yotatech.com/attachment....2&d=1236912602
Old 03-12-2009, 09:23 PM
dark_fairytales's Avatar
if you were closer to me i would teach you how to paint that thing like pro, painting is stress releiving for me. just google some painting lessons so you can get the idea of how to do it and then practice with a good primer job, if you up the primer you will not have to worry as you can always fix primer easy. if you have any question about different materials or procedures just PM me
Old 03-13-2009, 04:58 AM
pathfinder's Avatar
Thanks for all the input guys!
Old 03-13-2009, 05:05 AM
pathfinder's Avatar
...and don't be surprised if it ends up black with an A team red stripe to match the truck
Old 03-13-2009, 05:31 AM
pathfinder's Avatar
So, 15 lazy minutes with windows paint and I came up with these...I'm not artistic (autistic ). I'm thinking something along the lines of the last one but done properly!
Old 03-13-2009, 06:05 AM
InternetRoadkill's Avatar
Black and fiberglass don't mix. I used red marine paint on mine. Used a small roller to apply it.
Old 03-13-2009, 01:05 PM
GobBluth's Avatar
black canopies FTW!! a black canopy looks good on anything. the contrast stripe sounds like an awesome idea. this canopy used to be blue as well:
Old 03-13-2009, 01:43 PM
John101477's Avatar
I wonder if this would work with the top to my runner. The red paint is old and worn compared to the painon the truck.
Old 03-13-2009, 02:46 PM
pathfinder's Avatar
I just figured for someone who doesn't want to spend much money and doesn't have painting equipment black is easier with a spray can. I could get someone to add the red stripe or maybe even pinstriping.
ashamsuddin
17
01-13-2023 03:17 AM
kawazx636
10-06-2021 03:03 PM
ladybugRC
458
08-21-2020 10:41 AM
Toys4parts
09-26-2015 01:56 PM
Obmi
09-10-2015 03:36 AM
Quick Reply: Painting my Canopy???
