YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 02-03-2006, 06:21 AM   #1 (permalink)
rpeAMP's Avatar
Send a message via ICQ to rpeAMP Send a message via AIM to rpeAMP Send a message via Yahoo to rpeAMP
Ok so its NOT the headgasket...
I took my truck in for what I thought was going to be expensive headgasket work due to a gradual unexplained loss of coolant.
Left it overnight and called the next day to check the status and he told me that they could find absolutely no evidence that the headgasket it leaking:
- No oil in coolant
- No coolant in oil
- No exhaust gases in coolant (they checked 4 times)
- No steam or billowy smoke other than a bit of steam early in the mornings when cold (goes away after a minute or so)
- Kept system under pressure (16 lbs) overnight, with no leaks surfacing
What gives? What else could explain me having to refill the coolant tank every 500 miles or so?
__________________
Preston Edwards
1992 4Runner SR5 V6 4WD (5 Spd.)
246,000 miles & counting
2" Downey coils, 32x11.5x15 BFG A/Ts, Rockcrawler Series 51 wheels, Magnaflow exhaust, Yakima roof rack, ARB bull bar, SAW Torsion bars, (4) PIAA 520s, Cobra 18 WX ST II CB w/ Firestik antenna, hp iPaq GPS
2007 Toyota Tacoma TRD Sport 4WD (5 Spd. Auto)
400 miles & counting
rpeAMP is offline
Sponsored Links
To remove this ad, register today!
Old 02-03-2006, 07:00 AM   #2 (permalink)
smiljko's Avatar
Coolant leak?
No really- I've got two micro holes on my rad- it won't leak enough to see the pond underneath the car, bul when the system is under pressure it will leak a drop of coolant that dries out.Drop by drop -Ihave to add 0.5l every 5000km.
__________________
89 4runner SR5
22RE BIFUEL-LPG conversion,
BFG M/T
OME lift
smiljko is offline
Old 02-03-2006, 07:25 AM   #3 (permalink)
rpeAMP's Avatar
Well that's what I was initially thinking, until he told me they had cardboard under the truck for more than 12 hours, while under 16lbs. of pressure, with no leakage whatsoever.
__________________
Preston Edwards
rpeAMP is offline
Old 02-03-2006, 07:31 AM   #4 (permalink)
smiljko's Avatar
But when the engine is running metal expands,and antifreeze vaporizes. Look for the green white spots on the rad, and around ALL hoses especially connections.I'm sure you'll find the cause.
And yes-did you bleed the system completly?
__________________
89 4runner SR5
BFG M/T
OME lift
smiljko is offline
Old 02-03-2006, 07:32 AM   #5 (permalink)
Staff
Elvota's Avatar
How much coolant to you observe dissapearing when you have to add? Could your tank cap have a leak or other that might let coolant evaporate?
Really guessing here, but maybe one of the smaller water lines under the plenum, above the intake, has a small leak and fluid could gather on the intake instead of on the floor. That area of the engine is really hard to see and I know there is at least one hose that is almost buried at the back of the intake and two that go through the throttle body.
Elvota is offline
Old 02-03-2006, 08:07 AM   #6 (permalink)
snap-on's Avatar
Send a message via AIM to snap-on
I had a heater hose start leaking on the back of the block (water bypass block) and because it was back there it would drip down the back of the hot block and evaporate before it hit ground. but it only leaked AFTER the system got up to pressure (meaning the motor was hot)
i fought that for a good 4 months till the leek got bad enough were it started leaking on to the ground and i could finnally track it down.
same problem can be for the rad. small leeks evaporate before they make a puddle. (but only leak after it heats up and things expand)
__________________
94 EX cab, 5speed, V6, locked, ARB bar, NWOR headers
92 4runner, auto, V6, OME suspension, Downey headers
snap-on is offline
Old 02-03-2006, 10:26 AM   #7 (permalink)
habanero's Avatar
Send a message via AIM to habanero
I had a top seam rad tank leak that had to get worse before I was able to find it.
You could try parking over cardboard yourself after a drive.
There's a dye that can be put into the cooling system to check for leaks with a uv light, if you don't want to wait it out.
__________________
My rides:
'96 4Runner SR5 4x4, manual. Deckplate, ISR, extended rear diff breather mods, flipped receiver hitch, power antenna switch........
Quote:
Originally Posted by Tacoclimber View Post
Habanero - you ride a Gary Fisher, you change your own oil, AND you have a man-eating pumpkin pie as your avatar. You are anything BUT a soccer mom. :D
Quote:
Originally Posted by waskillywabbit View Post
..start giving him the literal 2 cents every time he butts in...if that gets out of hand...tape the 2 cents on the end of a hammer.
I (still....even though...) support BT17R.....but I forgot why.
habanero is offline
Old 02-03-2006, 11:03 AM   #8 (permalink)
Joyota's Avatar
Send a message via AIM to Joyota
Don't forget the heater core hoses under the dash.
__________________
~ Joe ~ '89 4WD Pickup, Std Cab, 22RE, W56, 4.10's
{REPAIRS} Head Gasket, Timing Chain Guides, Water Pump, Alternator {MODS} Flatbed, Turn/Parking Light, SR5 Cluster, SR5 Lighter, SR5 Clock, 750W Inverter {ACCESSORIES} 33x12.5 on 15x8's (no lift), Radar Detector, CB, Contico Tool Box, Pilot Driving Lights, Fiamm Freeway Blaster {WAITING} Portable Air Tank, Big 3, Hood Scoop
Joyota is offline
Old 02-03-2006, 11:09 AM   #9 (permalink)
4x4Lamm's Avatar
I had this problem in my 92 also. It was the coolent resivoir tank. The seam where it was molded had a small crack in it so everytime the hot radiator dumped some coolent into it it would leak out a little bit (too small to notice on the ground) and I was slowly loosing coolent.
That would also explain why a preassure test does not cause a leak.
A $10 junkyard resivoir and 5 minutes of work fixed it all.
Lamm
__________________
The Rescue Runner:
1995 4Runner SR5 Limited, 3.0 V6, Auto, 4x4, 4.88 Gears, Downey HD Coils, SAW Torsion Bars, OME Shocks and Steering Damper, 15x8 Outlaw II Wheels, 31x11.50R15 Mickey Thompson MTXs, Marlin Sliders, BCC Rear Bumper, TJM T-13, Warn M8000 w/ Rockstomper Line, Emergency Warning Package
Destroyed By Fire:
92 4Runner, Lots of mods. I will miss it...
4x4Lamm is offline
Old 02-03-2006, 07:33 PM   #10 (permalink)
trythis's Avatar
If the engine was running while it was under pressure, then you could be certainabout everything, but when it gets hot, the hoses could even get squishy and seep water out, you don't have an oily greasy windsheild interior do you?
trythis is offline
Old 02-20-2006, 08:48 PM   #11 (permalink)
rpeAMP's Avatar
Thanks for all the replies. For some reason, YT stopped sending me e-mails so I didn't know there were this many replies!
I sure hope it's a pinhole leak somewhere in an obscure hose. A few questions:
- Where are the heater hoses located under the dash? I haven't noticed any internal leaks, but haven't been looking for any either.
- Is it possible that I have a headgasket failure so small that there would be no signs of exhaust gases in the coolant, or is it the type of thing where if there's no exhaust gases, there's no headgasket failure?
I sure hope that it's something small like a coolant reservoir leak.
__________________
Preston Edwards
rpeAMP is offline
Old 02-21-2006, 03:43 AM   #12 (permalink)
okidoc's Avatar
Not to rain on your parade, but when my HG went I had a slow coolant loss that held pressure warm or cold, gurgling heater sounds and a good amount of steam on cold mornings that didn't last more than 30 secs. The mechanic didn't think it was a HG at all but I asked him to check torque on the head bolts. He retorqued them about five over spec. It all stopped for six months, then I started breaking spark plugs on the number six cylinder and found that I was beginning to get chocolate milk where my oil was supposed to be. So I guess you can have a slow small leak that is difficult to diagnose and is fairly harmless if caught in time and monitored. The engine ran fine and pulled well all over the hills on the Olympic penninsula.
__________________
1995 3.SLOW 4X4 AUTO SR5
STOCK AND MORE RELIABLE THAN MY OLD JEEP
okidoc is offline
Old 02-21-2006, 06:43 AM   #13 (permalink)
Do you mean to say they found no evidence of coolant in your exhaust gases?
You keep saying it the other way around.
Analyzing the exhaust gas for coolant will tell you for sure that you leaking into a cylinder.
__________________
1994 3.0 4Runner (Original Owner) 171K
2003 Jetta GLI
Astralplane is offline
Old 02-21-2006, 06:46 AM   #14 (permalink)
Funk_Runner's Avatar
Quote:
My coolant was disappearing without any visible sign. When the shop hooked it up to test for contamination from the combustion chamber, it showed up immediately. In response to your question, I'm not sure, but I think the test would show exhaust gases.
Maybe your leak is at or beyond the radiator cap. This would explain the pressure holding steady during the test, but not while running. I would replace the cap, inspect the hose to the overflow and look at everything on or around the overflow.
__________________
-----KEVIN-----
1993 4Runner SR5 4x4 3.0 Auto 212,000K miles- Retired - To be replaced by 3rd Gen. SOON
1973 Volkswagen Transporter Automatic 78K original miles
1967 Mustang 289 - 57K original miles
Quote:
Originally Posted by celica
you need to be more careful with your balls.
Funk_Runner is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Few headgasket probs ShortyzKustomz 86-95 Trucks & 4Runners 3 03-30-2007 11:45 AM
please tell me its something other than my headgasket.... kpaxfaq 86-95 Trucks & 4Runners 10 09-05-2006 08:01 PM
Headgasket update. Mikronized Maintenance & Repair Archives 15 04-13-2005 04:23 PM
best headgasket? runnerboy97 95.5-2004 Tacomas & 96-2002 4Runners 4 09-30-2004 09:01 PM
headgasket TRunner 95.5-2004 Tacomas & 96-2002 4Runners 9 07-25-2003 01:23 PM
Advertise on YotaTech.com
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
