Is My Master Cylinder Dead.
Old 02-09-2006, 07:19 AM
4rnr's Avatar
My master cylinder worked fine, I did a sas, bled the brakes, I never put a block of wood under the pedal. I pumped it probably 500 times in my attempts to bleed the system. Did I over extend the piston too much. I cant get the brakes to hold pressure. Even if there was air in the lines the pedal would compress the air and then hold the position. but all it does is pump up firm and when you hold it it falls to the floor.
Its a 92 4runner v6.
I am thinking about upgrading to the fj80 MS but not sure if its worth money.
Also to bleed the cylinder I just run two brake lines out of the outputs and into the resivoir, and pump the piston until no air bubbles come out of the res. Is this all there is too it. is there something I have to do to keep air out of it as I install it?
Thanks guys Im in a hurry
Old 02-09-2006, 07:23 AM
4rnr's Avatar
Actually I just checked with car quest and the fj80 part # is the same part# as the 92 4runner MS so no upgrade necessary....I guess
Old 02-09-2006, 08:09 AM
midiwall's Avatar
Yeup... you have to hold the pedal down to the floor as you close the bleeder valves. If you don't, then the action of the pedal going up will suck air into the line.
Get a buddy to help, or pin the pedal to the floor with a 2x4.
Old 02-09-2006, 10:25 AM
4rnr's Avatar
Bleeder?? Im talking about the master cylinder I wasnt aware of bleeders (that would be nice) Im only aware of the two fittings, Ill double check.
Old 02-09-2006, 10:26 AM
breknraj's Avatar
Or get a manual vacuum brake bleeding pump/resevoir - I love having mine for changing fluid and bleeding the brakes!
Old 02-09-2006, 10:40 AM
4rnr's Avatar
Whats that? do you have a website or a place I can look at it
Old 02-09-2006, 11:01 AM
breknraj's Avatar
I bought mine through Griot's Garage:
http://www.griotsgarage.com
Item # 10122
I got this one because it's big enough to use for just about any fluid drain/transfer, but I've seen smaller (and cheaper) versions in other catalogs and auto parts stores - just look around, or search on eBay.
Old 02-09-2006, 11:34 AM
4rnr's Avatar
Item # 10122
Thats interesting is there a manual verison.
Old 02-09-2006, 11:45 AM
4rnr's Avatar
what kind of blleding to I have to do after I install the master cylinder. Im sure there will be air in the lines, do I bleed the same way and drag all that air through the system, or should I reverse the bleeding order, or is there a better way. Im finding that there a million tricks to doing this.
Old 02-09-2006, 01:08 PM
Elvota's Avatar
I use this for all types of bleeding, applying vacumm...
http://www.harborfreight.com/cpi/cta...emnumber=39522
I've seen this unit and similiar ones elswhere. Usually at auto shops.
In a pinch one time, I bought a huge (1" dia, 6" long or so) syringe at a pet store, and used this to pull fluid through the lines. Was slower though, but a lot cheaper.
Old 02-09-2006, 06:00 PM
midiwall's Avatar
Hmmm, I may have gotten our wires crossed, but I've also known to bleed the system through the lines even when replacing the master.
Maybe not...
Old 02-10-2006, 10:28 AM
breknraj's Avatar
#10122 is the manual pump. Go to the web link, seach the item number, and there is a good picture of it on the top left.
Capacity of the res is about 1 1/2 to 2 gal, an it stands a couple of feet high. VERY handy tool to have around!
4.34runner88
02-07-2016 02:24 AM
Hugh_Mann
09-16-2015 03:59 AM
user 82300
09-15-2015 05:49 AM
old87yota
09-09-2015 12:39 PM
Squigglez
09-04-2015 07:33 AM
Quick Reply: Is My Master Cylinder Dead.
