Looking for 3rd gen EXTENDED CAB truck mods - PICS OF 3rd gen EX CABS PLS.
Yes that is custom.
So far I have seen nothing that is extra cab specific. I dint think there are many mods which are, and they would be like stereo stuff.
If you just wanna see pics of trucks take a look here.
Location: Cincinnati, Ohio - Amelia is the exact place. There is no one else on this site from where I am. Seems like everyone is from Cali or Washington. I guess I need to move.
x's 2 on the air compressor that is really cool.
Here are the pics that you asked for. I also installed bucket seats out of a 4 runner.
#25
are those 6x9's in the access panels? What did you use to cut the plastic out, I want to do that same exact thing, I have wires in there already I am assuming those are pre run speaker wires? I like how you have the CB mounted into the dash.
#27
I really haven't had much a rattle problem.... that I know of. But with the 12" sub pounding away, I don't think that I would hear it anyway. I would like to see what you did with your rear speakers.
#28
That's interesting, those are actually storage locations? I've got 6 1/2" speakers there, obviously custom made with carpet covered wood. But the speaker wires are stock, with small amplifiers on each one.
#29
squiddy, I like your tire mount...I was just measuring my bed today thinking about doing the same thing. The only thing that I was semi-worried about was always having extra lbs on one side with my 35 stuck back there but I pretty sure I dont really care cause Im a fat-ass and am on one side so....
#30
i dont have pics handy right now but when i bought my truck it had 6x9s wired up in the small panel below the rear seats. it has the grills to protect them from being kicked out, and its not like whoever sits back there has enough room to mover there feet anyways...
the only mod i have that hasnt been posted is:
otherwise, i had success stuffing 35" BFG's on my 4" IFS lift
#31
One of the things that I have done to my truck in the extra cab part is my air compressor setup. I put the compressor inside in the extra cab storage bins so that it wouldnt see the elements, put the air tank under the bed, and I put the air chuck in with the gas cap.......
I've got the compressor, and will eventually put a tank in there as well. Looks like you have the relief valve and a drain on the tank.
#32
#33
Is that the extent of your setup? Do you have anything in place to control the compressor (pressure switch), or do you manually turn it off when it hits a certain pressure?
#34
http://www.amazon.com/gp/product/B00081FGEQ
I found one of these compressors at a pawn shop for 30 bucks. I removed the 110 volt compressor and used the tank upside down under my bed, used the pressure switch, the relief valve, and the drain off of it also. The only thing that I had to supply was the 12 volt compressor, for that I went to pep boys and bought the Masterflow MV-1050
#36
NICE TRUCK!
I copied your rear cap light mod. That cluster set up is sweet!
Nice work.
#39
That white dash through me for a loop. I can't stop looking at it.
I was originally gonna do mine black but now with that spoon in the mix...
As for my Xtra Cab specific mods, two 6x9's in boxes on the rear bench, storage is for straps and emergency gear. Tools fit snuggly under the seats and back pockets.
6th Gear
19
12-10-2019 07:31 AM
Colington
10-12-2015 05:41 PM
UKMyers
9
06-15-2002 12:57 PM
95Runner
06-09-2002 08:56 AM
