Lift Blocks + Parking Brake?
Old 05-23-2008, 08:33 PM
rusche's Avatar
Installing 2'' lift blocks to the rear of my '88 4Runner, but its shortening the parking brake cable!
Any quick solutions for this? Or is it safe too leave it?
Anybody encountered this problem before?
Thanks.
Old 05-23-2008, 08:35 PM
abecedarian's Avatar
I had 4" blocks and had no problems with the brake cable. Now I've got 4" springs and still no problem.
Old 05-23-2008, 08:36 PM
Staff
DeathCougar's Avatar
why are you installing blocks instead of leafs? ADd-a-leafs cost the same as blocks, and are much better
Old 05-23-2008, 11:04 PM
94toy4x4fever's Avatar
Death Cougar has a point! I have 2inch lift blocks on my truck and will be soon changing to add a leaf! But if you dont harcore offroad you might be ok for a while! I havent had any problems with the E break cable at all with 2inch lift blocks!
Old 05-23-2008, 11:24 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
The cable shouldn't present any problems being "shorter" unless your brake shoes start rubbing. Hell....you probably needed an "adjustment", anyway. They usually do after many o' years.
Typically if you lift the suspension in any way, the LSPV rod on the rear axle needs adjusting, too.....to raise the rod upwards again. You lose some of the rear braking power as the proportioning valve senses that the load is lighter than it really is. Might run a search on that.
Old 05-24-2008, 05:38 AM
rusche's Avatar
The block made the top of the leaf catch the cable, so instead of being straight it was bowed, seemed ok at that point, but im worried if I go over even a small bump wont it push the cable?
Old 05-24-2008, 05:46 AM
Robert m's Avatar
got any pics of this?
Old 05-24-2008, 05:49 AM
rusche's Avatar
Nope, I removed them last night as I have to go to work
I cant imagine Id be the only one whos encountered this before
Old 05-24-2008, 08:03 AM
Ya know, I think I know what you're talking about now. I thought you were just referring to the lift extending the e-brake cable.
The brake cables come across from the top of the differential to the levers that actuate the e-brakes. In retrospect, my 4" blocks lifted the springs high enough for the cables to pass under the springs and the lift springs I have now are like the stock springs and under the cables.
You're not going to get it working unless you can extend the e-brake levers high enough to attach the cables without interference from the springs or change the brake backing plate and mechanism to one that has the cable acting directly on the shoes.
Longer shackles or different springs are the only other choices.
Old 05-24-2008, 12:06 PM
rusche's Avatar
abecedarian, yup I was looking at it today, and realized that 4'' probably put the line under the spring.
I ended up going with just a 1'' block. Didnt entirely remove the rear sag, but helped alot
I'm eventually going to a new spring setup when I get a little more money, so if its not perfect for $25, I'll live
Old 05-24-2008, 02:29 PM
slacker's Avatar
eventhough you have fixed it .. I thought I would post up anyway ..
on my old rig , I had the same problem .. what I did was just cut off about an inch of the emergency brake leaver , re drilled the pin hole .. and re-attached the cable undernieth the spring ..
worked great for about 10 years ..
Flying91
45
04-11-2024 04:39 PM
06-01-2021 01:51 PM
09-04-2015 09:27 AM
terminator
07-27-2015 07:13 PM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: Lift Blocks + Parking Brake?
