Help name this seal!?!
Old 02-28-2013, 06:20 PM
Bertsch911's Avatar
Hey guys. Just swapped out a bad tranny on my 87 4runner sr5. Well I'm having a leaking issue with the new one. It's coming from the part where you bolt the rear axel to the tranny. It leaks behind the spindle. Is there a seal in their I can replace and if so what's it called. I took the spindle off of the old bad tranny and someone had red sealant in it. Can I replace the seal or should I just go ahead and use the red sealant like they did on the old tranny? Thanks guys!
Old 02-28-2013, 06:48 PM
Grego92's Avatar
Yours isn't 4x4? I did something similar and did a "How To". Got to my build thread, page 1, scroll half way down. I replaced the transfer case output seal.
Old 02-28-2013, 07:04 PM
stanprophet's Avatar
If you post some more info I can get you a break down. I am assuming this it the transfer case, MT or AT?
Here is a breakdown of the early type TC.
If there is a seal there, it will be called an output shaft seal.
Old 02-28-2013, 07:21 PM
Bertsch911's Avatar
Sorry yeah it's a 87 4runner 4x4 m/t. It's leaking out from behind that spindle
Old 02-28-2013, 07:37 PM
Bertsch911's Avatar
Would that be my transfer case gear oil that's leaking? So I can top it off after
Old 02-28-2013, 07:42 PM
Bertsch911's Avatar
Also where could I buy the seal? Do I have to go to dealer or does anyone know if parts store would have them?
Old 02-28-2013, 07:53 PM
Bertsch911's Avatar
Btw nice write up! That's gonna come in handy
Old 02-28-2013, 07:54 PM
yodafan93's Avatar
yeah a parts store will have it. got mine at advance.
Old 02-28-2013, 08:37 PM
Bertsch911's Avatar
Do you know what they call it. I searched there website and couldn't find it?
Old 02-28-2013, 08:42 PM
Roark's Avatar
Tell him its the transfer case output seal. Just print out that picture and show the guy and he should be able to find it. If not, try the dealership, he'd definitely have the part.
Old 02-28-2013, 09:39 PM
Bertsch911's Avatar
Thanks ill be callin advance tomorrow. Any preferences for the red sealant I should use?
Old 02-28-2013, 10:12 PM
Co_94_PU's Avatar
FIPG is color coded, brands are like girls everyone has thier favorite. Toyota will be pricey just pick a brand *shrug*
Old 03-01-2013, 03:02 PM
Bertsch911's Avatar
So I picked up the supposed seal from advance. I didn't like how they were different. The new one metal and smaller, versus the old rubber and thicker. So I called the toyota dealer and ordered it. 9.38 was the total. Should be here he said no later than Tuesday. What do you guys think about these seals from advance? Think it would have worked?
Old 03-01-2013, 03:06 PM
WD_40's Avatar
Frank. I will name this seal Frank.
Old 03-01-2013, 03:30 PM
Bertsch911's Avatar
Hahahah that was a good one
kawazx636
10-06-2021 03:03 PM
ladybugRC
458
08-21-2020 10:41 AM
Obmi
10-04-2015 11:30 AM
hiluxinargentina
09-30-2015 11:12 PM
hiluxinargentina
09-30-2015 05:51 PM
Quick Reply: Help name this seal!?!
