YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 09-06-2008, 01:31 AM   #1 (permalink)
The California Kid's Avatar
Send a message via AIM to The California Kid
Ghetto lift?
So I just bought an 88 4runner, and the guy I bought it from has 3 or 4 inch blocks in the rear, and I'm not really sure what he has in the front, but it is lifted about 4" as well. I don't see anything after-market in the suspension, so I'm assuming he cranked up the torsion bars? Is this bad? Should I keep it like this?
The California Kid is offline
Sponsored Links
To remove this ad, register today!
Old 09-06-2008, 04:12 AM   #2 (permalink)
91 4Runner's Avatar
Pictures of the front and rear would really help... If it is cranked - turn them back down, and loose the blocks.
__________________
Mostly Stock 91 4Runner SR5 V6 Auto w/ 33" Durango MT's (bent lower valance removed), bush bar w/ 55w Baja Offroad Lights, Custom fit 1st. gen rollbar (used to mount Hi-Lift and fire extinguisher), extended diff breathers, (Comming soon rear spool and 2" body lift..)
My very slow buildup on my site - currently building.
http://maddog11.proboards36.com/index.cgi?action=display&board=projects&thread=120 6828202&page=1
91 4Runner is offline
Old 09-06-2008, 07:25 AM   #3 (permalink)
Cranking the torsion bars limits suspension travel..if you go over a rough set of RR tracks it will shake the teeth out of your mouth...lower them down...lift it right.
project91 is offline
Old 09-06-2008, 07:51 AM   #4 (permalink)
Yeah thats what I was afraid of. I'm not sure how to lower them, but I'll give it a shot. Do they make cheap IFS lift kits? I think I know the answer to this but I'll give it a shot anyway.
Old 09-06-2008, 08:27 AM   #5 (permalink)
iamsuperbleeder's Avatar
Send a message via Yahoo to iamsuperbleeder
Quote:
if just the t-bars are cranked, then bj spacers would keep the same lift with relaxing the t-bars and getting the better ride back. not NEAR the price of an IFS bracket lift system...
may be something to look into, unless you only running 31's and dont need/want the lift or something; if thats the case, just relax the t-bars and go with it
if you do get the bj-spacers to keep the lift, ditch the blocks in the rear it do it up right with some new leafs, or at least maybe some shackles... something other than blocks; if you actually go wheelin with those blocks, it'll only be a matter of time before your stock leafs turn into the shape of an "S"...
__________________
91 Pickup, 4wd, 22re, stock suspention, rollin on 31s... for now that is...
290 thousand miles and counting...
Linkies:
YotaTech photos
MySpace
Quoties:
Quote:
Originally Posted by DeathCougar View Post
Take the oil cap off and throw it away, you dont need that. May as well drain the oil, dont really need that either. Just extra weight, and without that extra weight, you'll gain like, 400 horsepower!
Quote:
Originally Posted by toomanytoyotas View Post
4 tires in the air is o.k., so long as they are closer to the ground than your roof is...
iamsuperbleeder is online now
Old 09-06-2008, 08:37 AM   #6 (permalink)
abecedarian's Avatar
if you have a 'bracket' or differential drop type of lift kit, it'll look something like the following picture- notice the orange ovals I drew around the bolts:
__________________
Quote:
Originally Posted by Obama 'Ironman' Hussein
I want to ensure that everyone has the same capabilities off-road. Whether from the factory through high-dollar investments, from the aftermarket or by the hard work of the American backyard mechanic.
Therefore, I am taking some suspension travel from the more capable, more invested, more costly vehicles and transferring ... no ... redistributing that suspension travel to the other less fortunate vehicles. I am doing so in order to guarantee that everyone has the same opportunities off road.
abecedarian is offline
Old 09-06-2008, 08:47 AM   #7 (permalink)
Tofer's Avatar
Send a message via ICQ to Tofer Send a message via AIM to Tofer Send a message via MSN to Tofer Send a message via Yahoo to Tofer
even if you had 3 inch blocks out back, you're probably not going to see 3" of matching lift of out just a T-bar crank.... I'm going to bet you have ball joint spacers or a bracket lift. If i'm wrong i'd look into either one. you can find used ball joint spacers after someone does a Solid Axle Swap for 50-100 bucks. they are chunks of aluminum so it doesnt matter if you buy them used. you will need longer shocks to go with either type of lift. i will hypocritically say ditch the blocks, (i have 3" blocks on my pile as well). i've wheeled the piss outta it with out any problems having the blocks but it scares me to have them there. i am working on finding a way to keep the springs i have but not have to run blocks.
but instead of dealing with IFS lift, just SAS it and be done
__________________
3genRunner: including parts from 3 generations of 4runners, '92 pickup, '80something Land Cruiser, Chevy truck, Ford sedan
89 4runner: Project DD. 3.0, needs a new tranny
81 2wd pickup: 22R | 5-sp | long bed | quad hauler, leaks oil but gets 26mpg
91 Honda Prelude: the Daily Driver
WA, OR or CA wheeler?? Check out pacific-crawlers.com and check out yotaworks.com
Tofer is offline
Old 09-06-2008, 09:33 AM   #8 (permalink)
I'm just using the truck as a daily driver/commuter, with lots of trips up to Tahoe in the winter. I'll ocassionally wheel it, but nothing hardcore at all. Maybe a few trails here and there.
I want to keep the lift though. The girls think it's sexy I'll check out those BJ spacers, because right now, my front axles are at a weird angle
I'll take some pictures and post them up so everyone can see.
Old 09-06-2008, 03:34 PM   #9 (permalink)
well without a diff drop or bracket-lift system, your axles are gunna sit at quite an angel, even with bj-spacers. the only way you'll get the axles to level out a bit is to bring the diff down a little bit to be level with the center of the tires. but since your truck probably has manual hubs, that and the fact that you say you harldy ever wheel, you shouldn't have too much of an issue. the time people usually run into problems with axle angels from lift is with add front ends; they wear the boots out quick. there's always the possibility of binding issues with bj-spacers too, but that can be fixed with some bump-stops...
__________________
Linkies:
YotaTech photos
MySpace
Quoties:
Old 09-06-2008, 03:50 PM   #10 (permalink)
If you happen to have the ball joint spacers, this might be something to think of to help lessen the angles on the CV joints:
http://www.4crawler.com/4x4/ForSale/DiffDrop.shtml
__________________
Old 09-07-2008, 06:00 PM   #11 (permalink)
elripster's Avatar
Pics would be good.
If you have spacers and severely cranked torsion bars, as long as you have manual hubs you are fine. You'll be 4wd so rarely that will take a very long time to wear the CV boots.
To add, if you have a bracket lift and don't wheel hard, don't sweat the blocks in the rear suspension either. They will only become an issue if you start crawling in 4low.
Frank
__________________
1994 4runner, 3.0, auto, 5.71's, Truetrac (rear), 33's, BJ spacers, Coil spacers, air shocks, D-ring anchors, 4Crawler F/R swaybar discos, Marlin rear bumper.
www.sdori.com
elripster is offline
Old 09-07-2008, 11:29 PM   #12 (permalink)
4low crawling may be in my future as I found out today. I went to Hollister for the first time with my friends, and they are pretty much going to force me to play with my truck. They think I can do the mini tank-trap... i'm not so sure about that one
Old 09-07-2008, 11:34 PM   #13 (permalink)
NwRunner's Avatar
Cranked Tbars=Bad
My friend destroyes a pair of 33inch Toyo MT because he cranked the Tbars to get them to fit.
The outside edges where bald, completly. And the insides where fresh after like 3 months.
__________________
1996 4Runner- Dead
1996 Tacoma SX Alive
My 96 Taco Cleanup
NwRunner is offline
Old 09-07-2008, 11:57 PM   #14 (permalink)
Quote:
Originally Posted by NwRunner View Post
Cranked Tbars=Bad
Ok, but did he ever get it aligned?
Mic09dcsm is offline
Old 09-08-2008, 04:41 AM   #15 (permalink)
elripster's Avatar
I second the alignment. His tires wore because he didn't align it after cranking, not solely because they were cranked.
So did you ever verify you have a bracket lift? To crank torsion bars for 4" is, well, borderline impossible. You a-arms would be pointed downwards at a very steep angle and you'd have no downtravel left.
Frank
__________________
www.sdori.com
Old 09-17-2008, 08:40 PM   #16 (permalink)
I'm not sure about 4", but they have a pretty decent gap... and my upper control arms are definitely angled downwards. A lot!
When I get the truck back from the shop tomorrow, I'll try to remember and take pictures for yall
Old 09-17-2008, 08:44 PM   #17 (permalink)
Jay351's Avatar
Send a message via MSN to Jay351
Il bet that the PO added the big lift blocks to lift and "fix" the toyota sag. I bet its lifted 1-2" over stock. You can crank the t-bars that much, but its baaaaaaad
__________________
91 Pickup - xcab - 5sp - 3.0 - sr5 - 4x4 - 230,000kms |2.25" catback w/ magnaflow cat + glasspack | Weasy2k cams | Aisin manual hubs |Diff breather mod | Marlin HD clutch |3" BL | es3000's |2" AAL |1.5" bj spacers | ISR | Alpine headunit | 4" Infinity fronts/5" rears | 4.88's |Rear lockright | 33x12.50" BFG M/T on 15x8" steelies |Hella 500's |4" reverse lights| Grant GT |Downey idler arm brace|hella E-codes| Marlin armor | %100 Amsoil synthetic
http://www.cardomain.com/ride/2572486
Jay351 is offline
Old 09-17-2008, 08:49 PM   #18 (permalink)
dbl. pst.
Old 09-17-2008, 08:51 PM   #19 (permalink)
What size are the tires and how far from the tire to fender? We could tell right away if it was lifted that way. At least beyond how far t bars go, I think mine stopped before 3".
Old 09-17-2008, 08:54 PM   #20 (permalink)
4Crawler's Avatar
You can measure the front lift as noted below:
http://www.off-road.com/trucks4x4/ar....jsp?id=398514
Stock distance from the top of a 15" rim to the arch of the front wheel well is 13.5"-14".
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs.
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
