get rid of crossover pipe
Old Nov 19, 2007 | 05:20 PM
mrnick1979's Avatar
do you guys know any other way to get rid of the crossover pipe with out getting headers and using the stock manifolds?
Old Nov 19, 2007 | 05:21 PM
mrnick1979's Avatar
crossover 3.0
i want to remove my crossover pipe on my 3.0. is there any way other than headers?
Old Nov 19, 2007 | 05:25 PM
nate V's Avatar
Wee dude I dont have an answer for you but If you find out a solution to you problem i would be very interested for myself.
Good luck
Old Nov 19, 2007 | 06:27 PM
Tacoma750's Avatar
To me..headers is the way to do it. Why dont you want to go that route?
Old Nov 19, 2007 | 06:35 PM
nate V's Avatar
Yeah I guess that would be the easiest way to go about it.
I priced them out b4 and could not find them cheaper than like 500 bux
Although it would save the #6 cylinder from over heating all the time
on the other hand I read threads about people smoking speed cable and
e-brakes.
Old Nov 19, 2007 | 06:57 PM
Green93's Avatar
When I was debating if I should get headers or not I tried to find another solution. You could get an exhaust shop to bend up some pipe coming off the manifold where the crossover bolts onto. This would have to be about a 90* bend but then you could drop straight down and crossover under the truck like with headers. You would have to make a block off plate for the second opening on the drivers manifold where the stock exhaust bolts too. In the end I just bought headers. Either way gets rid of the crossover but I figured headers were the way to go for me.
Jason
Old Nov 19, 2007 | 07:10 PM
nate V's Avatar
yeah I hear ya
what did that hit you for ?
What make headers do you have ?
Old Nov 19, 2007 | 07:12 PM
Tacoma750's Avatar
The owner of this thread seems to have great ideas on how to fix things anfab things. maybe PM him?
https://www.yotatech.com/forums/f116...repair-130271/
Old Nov 19, 2007 | 07:15 PM
nate V's Avatar
hahahahahaha
here we go again
I bet hes going to be a pretty hard person to track down now
Old Nov 19, 2007 | 07:20 PM
jasond's Avatar
What i did when i swapped a 3.4 into my truck, I took the original crossover pipe and cut the flanges off that bolt up to the mainfolds. From the inside of those flanges a 2" hole saw fits very nice, took out all of the original pipe that was welded in there and left a nice spot for the muffler guy to fab up an exhaust from there.
Old Nov 19, 2007 | 07:33 PM
Green93's Avatar
Originally Posted by nate V
yeah I hear ya
I went with LCE headers. They were $650 when I bought but now they are $800. This includes the crossover and all hardware though. Everything is ceramic coated. Wish I could tell you how they work but the truck is still sitting. LCE's header was brand new and I guess they didn't realize that the crossover they fabbed wouldn't fit on an auto truck. Auto crossover should be here this week, hot off the assembly line. They are slow(mostly to do with the new product) but the quality is nice. Some pics here:
https://www.yotatech.com/forums/f116...ebuild-125970/
Jason
Old Nov 19, 2007 | 07:37 PM
95RunnerSR5's Avatar
here's what i did, using stock manifolds
https://www.yotatech.com/forums/f116...y-turn-119799/
Old Nov 20, 2007 | 03:18 AM
lukeland's Avatar
when I convert to standard im going to use 2 passenger manifolds for both cyl banks. and use the 2 90 deg bends from the crossover tube to 90 deg down turns and then fab the rest of the system.
Old Nov 20, 2007 | 04:50 AM
nate V's Avatar
Sounds like you got your work cut out for you.
But a whicked cool idea Pix.. when you do it deffinatly
kawazx636
Oct 6, 2021 03:03 PM
live4soccer7
May 11, 2016 06:52 PM
Obmi
Oct 4, 2015 11:30 AM
hiluxinargentina
Sep 30, 2015 05:51 PM
AustinTaco
Sep 18, 2015 08:58 PM
