front spindle question
Old 03-01-2009, 06:09 AM
jmcgowan's Avatar
I searched the forums first for part number cross reference and found nothing... Here's my question I have a 1994 2WD, and I'm looking for a set of stock front spindles. Will the spindles from a 1987 2wd work ? From what I can find here it's the same part #:
1994
http://www.toyodiy.com/parts/p_U_199...DEAB_4802.html
1987
http://www.toyodiy.com/parts/p_U_198...-KRA_4802.html
Old 03-01-2009, 08:07 AM
abecedarian's Avatar
spindles should be the same from 84-95
Old 03-01-2009, 08:19 AM
iamsuperbleeder's Avatar
are you positive? 2wd now...
I'm pretty sure 4wd's are, but I have no knowledge about the 2wd
the brake caliper mounting holes look a little further apart on the pics of a 94 spindle, maybe because of a brake upgrade? I dunno...
Old 03-01-2009, 09:03 AM
Staff
DeathCougar's Avatar
Toyota has different part numbers for the spindles through the years.
However, they use the same size brake rotor and caliper from 84-95, assuming you match 4cyl base to 4cyl base. The DLX and SR5 models use larger brakes than their predecessors.
Old 03-01-2009, 09:22 AM
that's what I meant, 2wd spindles from 84-95 should be the same.
from what I've gathered, even the 1 ton 2wd uses the same spindle, just different hubs / brakes
I may be wrong though.
kazuya2416
04-05-2024 02:17 AM
oldirtydirt
02-23-2020 09:30 AM
tj884Rdlx
08-28-2015 12:04 PM
88sasturbotoy
08-11-2015 01:56 AM
icentropy
07-14-2015 10:23 AM
Quick Reply: front spindle question
