flashing o/d light
Old 08-17-2007, 09:17 AM
Kiff's Avatar
flashing o/d light
Got in my truck to drive home last nigh, put on the turn signal and I notice that the o/d light is flashing slowly. Anyone know what this means?
Old 08-17-2007, 09:53 AM
eric-the-red's Avatar
That means the computer has stored a trouble code for the transmission, similar to the 'Check Engine Light'.
Old 08-17-2007, 11:56 AM
4runnerx3's Avatar
It means the transmission computer has a code. What year truck do you have? Here are the codes for 1st gen.
On my 4runner, you ground the square plug shown below, switch the ignition on with OD on and the light will flash the code.
Old 08-17-2007, 12:31 PM
04 Rocko Taco's Avatar
do you realize the flash code for code 64 and code 65 are the same?
Old 08-17-2007, 02:30 PM
4runnerx3's Avatar
Solenoid #3 controls torque convertor lockup for 3rd and OD. Solenoid #4 activates the t case.
Old 08-18-2007, 11:49 AM
Kiff's Avatar
I have 91 4runner. the speedo cable had just broken earlier that day, so i'm thinking that may be the cause
Old 08-18-2007, 01:57 PM
4runnerx3's Avatar
The first gen's have a speed sensor for the tranny in the instrument cluster.
Old 01-29-2010, 09:24 AM
calipatient's Avatar
i know this was a while ago but...
does this mean 64 and 65 will flash for the same solenoid? 64 and 65 are both for the same lock-up solenoid? or are there 2 seperate? 1 in the tranny and 1 in the tcase?
Old 01-29-2010, 07:20 PM
4runnerx3's Avatar
The diagram shows the same number of pulses for both codes, a mistake I think.
Liadrin
04-25-2022 02:54 PM
Shoua
13
05-22-2016 05:19 AM
AkitaDog
09-01-2015 08:05 AM
Liadrin
09-01-2015 06:44 AM
vanion2
07-29-2015 06:17 PM
Quick Reply: flashing o/d light
