Drain holes in frame ???
Old 12-13-2006, 11:49 AM
swerks's Avatar
Question Drain holes in frame ???
I was told today that I might want to drill extra drain holes in to my frame. because of its box construction it will hold water. any body doing this??? I have not heard this advice before.
Old 12-13-2006, 11:58 AM
CJM
CJM's Avatar
Unless there are already holes in it, how would water get in? Water will ge in through holes you drill to drain it too.
Old 12-13-2006, 01:13 PM
da_bigg_wigg's Avatar
The last thing you need is more holes for crap to get into. You also have to worry about rust proofing. Drilling holes in frames for no reason doesn't seem like a good idea to me...
Old 12-13-2006, 01:21 PM
all_terrain17's Avatar
Don't bother. If that was a problem, hopefully Toyota would have addressed it. Like the others have said you don't need anymore holes in your frame...why weaken the frame to keep it from weakening?
Old 12-13-2006, 02:41 PM
jaymo's Avatar
I agree no need for more..
But be careful of the tube crossmember behind the tank. Water must get in there and sit, cause mine rotted from the inside out. Im replacing it this week.
Old 12-13-2006, 02:52 PM
CyMoN's Avatar
I spray mine out with a high pressure washer every few months
Old 12-13-2006, 03:01 PM
Sonofmayhem's Avatar
One, deep water, two carwash, and the water will drain right out wont it.
I would do one by the rear spring hanger mount, the only issue is rust proofing you could paint it then get a brush and jam it in there to get the top.
Strength can be dealt with holes of the right size add surface area. hence more area to spread the weight.
young buck
18
08-27-2018 02:40 PM
Jcrawl94
10
10-24-2015 04:34 PM
yourrealdad
07-21-2015 11:13 AM
kcaudill
07-20-2015 12:06 PM
daddio
07-18-2015 10:20 AM
Quick Reply: Drain holes in frame ???
