CV Boots on an 87 IFS
Old 04-11-2007, 04:41 PM
RiNkY's Avatar
Hello - New to the forums. Just picked up a 87 4Runner IFS 4x4 5spd, the CV boots are all blown up front and it needs a new alternator - But other than that she is in good shape for the $750 I paid for her.
Is the replacement procedure listed at: http://personal.utulsa.edu/~nathan-b...18frontdri.pdf the same on the 87 as on the 93?
If not, does anyone have the FSM page for the same procedure on an 87?
Gonna just replace the axles and CV boots at the same time most likely as it has 176k miles on it, then I will have a couple of spares for the trail. Not tackled something like that before tho, my mechanical experience up to this point is Oil Changes and Brake jobs. Hope to do all the work on my new Toy myself tho and learn as I go along.
Thank you.
Old 04-11-2007, 04:50 PM
thegreydog's Avatar
If you can do brakes it should not be a problem. Just remove the hub and get it down to the rotor. The one problem I wasn't planned for was the large nuts behind the hub, I believe it was a 2 inch or 2 1/4. You definitely need it to get the hub assembly off.
Old 04-11-2007, 04:53 PM
RiNkY's Avatar
I live less than a mile from Harbor Freight (Dangerously close) I also have quite a few tools. Not sure if I have something quite that big, but I dont mind buying whatever is needed to pull the parts.
Old 04-11-2007, 04:58 PM
ChickenLover's Avatar
It's 2 1/8 or 54mm.
Old 04-11-2007, 05:00 PM
MudHippy's Avatar
54mm Toyota spindle nut socket. You don't need it to pull the CV half-shafts, but you do need it if you plan on doing your own wheel bearing/rotor maintainence. So it's a good thing to have regardless, alot of people try to get by w/o one but it's not smart. And that's a fair price including shipping. The whole operation is a pain in the neck, but you gotta learn how eventually.
Here's a quick tip: Pull the lower shock mount bolt, with it out of the way the cv shaft will be easier to remove/install.
Old 04-11-2007, 05:10 PM
RiNkY's Avatar
Originally Posted by MudHippy
54mm Toyota spindle nut socket. The whole operation is a pain in the neck, but you gotta learn how eventually.
Awesome - Thanks for the advise. Just ordered the 54mm Socket on Ebay - $23 inc. Shipping. So will tackle this weekend after next most likely.
Old 04-11-2007, 05:24 PM
thegreydog's Avatar
54mm Toyota spindle nut socket. You don't need it to pull the CV half-shafts, but you do need it if you plan on doing your own wheel bearing/rotor maintainence. The whole operation is a pain in the neck, but you gotta learn how eventually.
Ok. I guess I was a little confused when pulling the rotors. It looked like it would be removed to pull the shaft out. Wouldn't all that have to be removed to get the axle out?
Old 04-11-2007, 05:31 PM
MudHippy's Avatar
There's just a snap-ring and a bolt w/washer in the end. You have to open the hub locker to remove the bolt, then remove it (hub locker) to get to the snap-ring IIRC. Then the half-shaft will slide out.
Old 04-11-2007, 06:10 PM
RiNkY's Avatar
Will be pulling the bearings to repack them eventually - Maybe even the same day I do the CV Boots, so will need the 54mm eventually.
Old 04-11-2007, 06:16 PM
Chapman88SR5's Avatar
Shame on you! Should have ordered from WabFab!
Old 04-11-2007, 06:30 PM
RiNkY's Avatar
I'm new here - Never heard of em!!! Plus I'm impatient - Hense why I purchased what I needed as soon as I knew I needed it. But then he changed is mind and I didn't actually need it for the CV boots! lol.
Just checked the pics of your rig. A little scary how similar yours looked to mine and how much I want mine to look like yours! lol. Love what you did with the center console. Mine is all torn up like yours looked like in one of the first pictures.
Here's mine - http://www.rinky.us/NewRunner1.jpg
Old 04-11-2007, 06:49 PM
Wow, they did look pretty similar!
Old 04-11-2007, 07:34 PM
tc
tc's Avatar
Be sure to lube up the spindle bushings while you have the CV's out.
There are several writeups on here how to change CV's - all '86-'95 are the same.
Old 04-11-2007, 07:38 PM
MudHippy's Avatar
Yep, temporary lapse. I wasn't remembering the first time I changed a boot and that I hadn't yet purchased the spindle nut socket at that point, either. Anywho, that's http://wabfab.org/ so's ya know.
Old 04-11-2007, 07:45 PM
tc
tc's Avatar
Oh - and since you're gonna 'wheel it, you should knock out the studs and replace them with bolts. Will make future CV changes MUCH easier. M10-1.25x30mm IIRC.
http://toyota.off-road.com/toyota/ar....jsp?id=186218
Old 04-11-2007, 08:55 PM
hodgepodge79's Avatar
Yep, to remove and replace the cv shafts, all you really need are some common sockets, some combination wrenches, snap-ring pliers, and perhaps a chisel (or drift) and hammer for the cone washers. You don't need a spindle socket, heck, you don't even have to take the wheel off.
Pay a little attention to how the hub comes off. Having a buddy in the cab to apply brake when you are loosening the nuts on the inner flange of the cv shaft helps too.
I removed 3 of the 6 studs from each side and ground down the splines so they are snug, but slip out easily.
Old 04-11-2007, 08:58 PM
TNRabbit's Avatar
WabFab has the socket for $14, dude.
kawazx636
10-06-2021 03:03 PM
83yotastockR
11
11-10-2015 06:54 AM
dirk89
10-01-2015 05:15 PM
hiluxinargentina
09-30-2015 05:51 PM
89YodaRunner
09-30-2015 02:18 PM
Quick Reply: CV Boots on an 87 IFS
