Cant get my steering stabilizer off my runner!
Old 10-22-2009, 09:28 AM
4runner530's Avatar
I got the first bolt off but the driver side one will not come off
I have beat it with a sledge hammer and ggot a pickle fork to pry it off but no luck
any help?????!!!!
Old 10-22-2009, 10:41 AM
jd20phill's Avatar
Had to do this two days ago. Go to Autozone and get a tie rod puller (kinda looks like a clamp with a bolt running through it). Put it on, tighten the bolt, and pull that sucker right off.
Old 10-22-2009, 10:55 AM
OutlawMike's Avatar
x2, it will pop that thing right out of there.
Old 10-22-2009, 12:29 PM
Matt16's Avatar
pickle forks suck. pitman arm puller are just big TRE pullers and they'll get the job done.
Old 10-22-2009, 12:40 PM
A.Wilson013's Avatar
Screw that. Get a propane torch and cook it off.
Alex
Old 10-22-2009, 01:48 PM
Tragic Drive's Avatar
I used a sawzall on mine.
Old 10-22-2009, 02:31 PM
kornhuskerwizard's Avatar
x2 on the torch, i like fire... or a plasma cutter...metabo is cool too, it sparks
Old 10-23-2009, 12:33 PM
4runner530's Avatar
Thanks guys, I went to auto zone and got that tire rod puller and poped that bitch right offThe stabilizer is a must have upgrade if your always on the trail
Old 10-23-2009, 12:34 PM
4runner530's Avatar
How much was it to swap the 3.4 in there, I have a 95 and I hate that 3.0!
Old 10-23-2009, 04:12 PM
Jay351's Avatar
Puller. Buy one and you will thank yourself everytime you do front end work.
Its so easy just to tighten the sucker on, and pop shes off.
Instead of ramming a pickle fork in there (forget reusing the boot on that joint) or just smashing it with a sledge..
Old 10-23-2009, 05:58 PM
Matt16's Avatar
Tighten the puller up to a bunch, then tap it the side of the hole with two hammers at the same time. It should pop right out. Be careful about applying too much heat to the tie rod (not tiRe rod) as it has been heat-treated and sees a lot of force- you don't want to weaken it any.
MMA_Alex
25
04-18-2017 05:07 AM
toyota32
07-06-2015 05:42 PM
Jnkml
07-06-2015 01:20 PM
HRDC0R19
07-05-2015 06:43 PM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: Cant get my steering stabilizer off my runner!
