Braking problem!?
Braking problem!?
This gets really annoying, when I go to brake some what hard it swerve to the right, it used to do it to the right now its the left, I bled both brakes like crazy could it be alignment? help!
I didn't think calipers because he said that it used to pull one way, now it pulls the other way...so.....
Unless one fixed itself, or the other caliper got twice as bad as the original bad one??? lol
Well Im going to take it in to the toyota dealer for the recall and I guess they do a free alignment so I let you guys know if thats it, but the pistons on the driver side where kinda hard to push when bleeding, how easily should I be able to push them?
I'm pulling hard to the left. I have a new caliper on the left side. I took the right off last night, and it looks like the 2 outside pistons are working, and the 2 inside ones are frozen. I can put a piece of cardboard between the brake pad and the rotor.. Time to give autozone another $40 I guess!!
Definitely check the calipers to see that all 4 pistons are moving freely. if you're lucky enough to be able to get them all out without damaging them, a rebuild kit is only like $4-5
jasonty
41
12-23-2018 01:00 PM
skoti89
09-11-2015 07:46 AM
Johntom240
7
07-13-2015 12:18 AM
Jnkml
07-06-2015 01:20 PM
