94 4Runner problems after suspension lift
Old 06-20-2007, 09:35 AM
TC4RNR's Avatar
hey guys and gals, i posted this on the other forum, folks over there refered me here for some kindly advices.
94 4Runner 4WD, 3.0V6, 5spd. appox. 130k miles. over this weekend i had a shop putting in a pair of OME N72F shocks and FJ80 rear coil springs.
the result is ok, truck runs great and pretty straight, it lifted the rear about 4 inches ( i only wanted 2 inches). but i found a new problem after the lift, looks like the upper body is shiftted to the left a little bit, see the picture
before:
after:
left side:
right side:
couple guys said the problem is on the panhard bar, which i have no clue what the heck is going on. it'd be appreciated if you folks can point me to the right direction to solve this.
p.s. the shop is NOT a 4x4 specialty shop, just a regular repair place, which always does a good job for me. i'm planning on bringing it back to the shop on the weekend let them check it out, but before i do that, i'd like to hear you experts here so i can give them a hint or two.
thanks.
t.c.
Old 06-20-2007, 10:09 AM
frodin1's Avatar
You didnt do your homework before throwing on a set of LC coils. The Panhard is the big bar that runs along the rear axle. If you only wanted a couple inches of lift you could've gone with a set of OME's. The option you have now is an adjustable Panhard bar from Sonoran steel $200. I'm unsure if there may be a bracket for your year? This evens out the rear end. And keeps it from bouncing all over the road when you hit a bump. If you go to http://www.sonoransteel.com/ there's all kinds of info regarding this. Good luck.
Old 06-20-2007, 11:44 AM
Motayota's Avatar
Yes, this is what your problem is, you changed the geometry of the rear suspension and your OEM Panhard bar is pulling your frame to the left or pulling your axle right, however you want to look at it.
http://www.sonoransteel.com/store_drop_bracket.html
Also, from what I've heard, your LC coils will settle a bit to about 3" of lift so wait and see, but if you want only 2" then go with the OME's.
Old 06-20-2007, 11:49 AM
dijlop's Avatar
btw, u drew the lines in different places. the left side is draw right on the outside of the wheel, while the right side is about an inch or two in on the wheel. lol.
Old 06-20-2007, 12:01 PM
yotasavg's Avatar
i have this same problem. i went with the ome shocks and ome 901 coils. about 2-3 inches of lift, including the corected mega-sag. the coils are great and a panhard relocation bracket will correct your body offset.
you can get one from 4crawler.com
Old 06-20-2007, 04:27 PM
TC4RNR's Avatar
yeah, i took these pictures in a hurry before i went to work. i just took these two from top of a ladder.
driver side wheel
passenger side:
Old 06-21-2007, 09:56 AM
TC4RNR's Avatar
I called Steve at Sonoran Steel, very nice guy, by the way. he recommended the Pro Comp traction bar bracket, therefore i can keep the factory traction bar. unforturently, Sonoran Steel does not make adjustable traction bars for 2nd gen. 4Runners.
what do you guys think abou this? $32.99 at Summit Racing.
http://store.summitracing.com/partde...145+4294806857
Old 06-21-2007, 01:12 PM
yotasavg's Avatar
driver side wheel
passenger side:
a simple drop bracket will solve that.....it's not a big deal at all.
Old 06-21-2007, 01:16 PM
faubrunner64's Avatar
yeah panhard drop bracket for sure!
Old 06-21-2007, 01:21 PM
curly_c's Avatar
http://4crawler.com/4x4/ForSale/CoilSpringSpacer.shtml
get yourself one of them drop brackets.
Old 06-21-2007, 05:31 PM
vrmark2's Avatar
I'm running ome coils and 2" spacers and my axle still sits offset an inch with the bracket.
Old 06-21-2007, 06:24 PM
AndYota's Avatar
x2 on a drop bracket. I got one and it fixed it right up.
Andy
6th Gear
19
12-10-2019 07:31 AM
voiddweller
19
05-02-2016 09:10 PM
Tommy T.
07-05-2015 07:48 AM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: 94 4Runner problems after suspension lift
