90 4runner transmission problem help!
I have a 1990 4runner which has been sitting for about 3 years. I just decided to get it going again so I replaced the fuel tank, fuel pump, and fuel lines. Also changed all the fluids and the water pump and timing belt. Changed the spark plugs and installed a new battery. It started up and runs like a champ. I took it out to drive and the transmission is now shifting very weird, it will not shift until I hit about 4,800 rpms. Please if anyone has delt with this before let me know.
You can easily determine whether the problem is mechanical or electrical by doing a manual shifting test as described in this link...
http://personal.utulsa.edu/~nathan-b...33manualsh.pdf
The test is easy do to, and will help diagnose the problem.
06-01-2021 01:51 PM
MMA_Alex
25
04-18-2017 05:07 AM
Jnkml
07-06-2015 01:20 PM
