89 22re resonator air requirements
I'm trying to get the Supra stuff installed on the 89 and there is a resonator that goes to the PAIR valve and it hooks into the air box. On the 86 it wasn't there so I didn't need to plumb it in. On this one the small filter that I bought to use on top has a much smaller hole than the hole in the top of the resonator. What I need to know is how much air does the resonator need? Can I cut the air flow to that thing by half and still use the filter I have without messing something up or do I have to let it breath out of the full 1/2" hole it has?
pic
pic
The ecu's calibration for dealing with the air from the PAIR and how it affects the O2 sensor might be off causing the mix to go a little lean (no O2 from the pair would appear rich, correct?). Other than that and the legality of removing smog equipment (varies by locale)... probably nothing.
It doesn't take any HP to operate the thing so I don't see much of a benefit to removing it.
lol, well ok then
montanatruck
02-26-2017 07:07 AM
Jeffreynmandy
07-18-2015 08:26 AM
