87 22R 4X4 PU Drivetrain Vibration
Old 02-10-2007, 10:34 PM
Ebin's Avatar
I get a significant vibration in the drivetrain when I let up off accelerator. Vibration nonexistent when under load. Several years ago some moron replaced clutch. Related problem? UJoint? Flywheel? Rear-end? Clutch??
Old 02-11-2007, 04:23 AM
Flash319's Avatar
Probebly U-joint. Could also be the crossmember rubber mount or your hanger bearing on the extra cab trucks. If it is a very light vibration I found it was always the rubber mount.
Old 02-11-2007, 04:05 PM
Stock 87's Avatar
Could be a u joint or the output bearing on the transfer case. Got a bad one in my 87 P/U 190k. Check to see if its throwing oil on the bottom of the truck. If it is you'll have to repace the bearing & seal.A bad bearing won't allow a new seal to work effectively becauce the output shaft is wobbling. And this is were the vibe comes from.
Old 02-11-2007, 10:16 PM
Ebin's Avatar
Thanx for the help guys.
Old 02-11-2007, 10:54 PM
mochester's Avatar
mine did something like this and it was not the u joint. it was the carrier bearing. not in the rear end, in the middle of the driveshaft. the driveshaft also turned out to be bent or unbalanced or whatever the case was. it tore up my ring and pinion eventually. get it taken care of.
Old 02-14-2007, 09:00 PM
Ebin's Avatar
Update - It's the output bearing on the transfer case. Thanx guys
Old 02-15-2007, 05:49 AM
rdlsz24's Avatar
Was your transfer case leaking? Mine leaks moderately, and I do have a wobble if I'm off the gas at highway speeds. I always thought it was from my worn front tires or alignment.
Rob
Old 02-15-2007, 08:26 PM
Ebin's Avatar
Leaking only in the sense of throwing gear oil onto the bottom of the truck.
Old 02-16-2007, 11:10 AM
rdlsz24's Avatar
No mine leaks gear oil onto the ground.
Rob
Old 02-16-2007, 03:51 PM
ShortyzKustomz's Avatar
Mines doing the same exact thing. U joints dont have any play, how can you tell if its the output on the transfer case and how hard is it to replace the bearing?
Old 02-16-2007, 09:36 PM
Ebin's Avatar
rdlsz24...Sounds like xfer case ouput shaft oil seal. As far as the bearings go, I'll let you know how hard it is tomorrow nite.
Old 02-17-2007, 09:48 PM
Ebin's Avatar
Wasn't bearings after all. The shady shade tree mechanic who changed the oil seal last didn't but the flange to spline nut on right.
dumpster84
04-30-2016 06:03 AM
Nailit69
Diesel Swaps
07-21-2015 05:28 PM
MTLroadierunner
07-20-2015 03:07 PM
skoti89
07-06-2015 07:45 PM
Quick Reply: 87 22R 4X4 PU Drivetrain Vibration
