3.0 rough at 1500 - 2000 RPM
Old Feb 17, 2007 | 02:05 PM
KonaYota's Avatar
'92 4runner with 308K miles is running rough and missing at 1500 - 2000 rpm. Items done: new plugs, air filter, timing, fuel filter, seafoam in gas tank, replaced any suspect vacuum lines, compression check (115 on left 3 vs 140 on right). Am I missing anything easy. My next step might be to go to local mechanic for diagnostics. Thoughts?
Mahalo from Kona Hawaii
Old Feb 17, 2007 | 02:12 PM
keithguts's Avatar
You might have a bad or cloged fuel injector. Do you here any tapping noise at all.
Old Feb 17, 2007 | 02:16 PM
KonaYota's Avatar
Nothing out of the ordinary. Will seafoam in the tank help? I've only run the sefoamed gas for about 20 minutes.
Old Feb 17, 2007 | 09:35 PM
Ebin's Avatar
I ran about 20 cans of seafoam thru mine....didn't help a bad fuel injector. I had same probs as you.
Old Feb 17, 2007 | 09:39 PM
KonaYota's Avatar
OK, How do I diagnose a bad fuel injector? I don't seem to have any noticable missing at higher RPMs.
Old Feb 17, 2007 | 10:49 PM
DudeBud's Avatar
how old are the plug wires and dist cap? pull the plugs back out, find the one that is not firing, if its dry then i would guess it's the injector, if its wet with gas then look to the wires or even the cap. I noticed on mine that that it did not take long for a new dist cap to get corroded and cause it to miss. Also your compression numbers don't look so good.
Sleaker
Aug 26, 2020 06:03 AM
Dakotaneu
Jul 27, 2015 12:03 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
ty1er
Jul 19, 2015 06:42 PM
redghost.308
California SoCal
Jul 16, 2015 07:46 AM
