63in chevy mounts
Old 11-04-2011, 08:31 AM
runs-on-4's Avatar
63in chevy mounts
anyone suggest getting these
http://www.lowrangeoffroad.com/yotam...-swap-kit.html
does anyone have a better link?
Old 11-04-2011, 09:05 AM
scuba's Avatar
That's a decent kit. Decent price for 1 stop shopping. I'd buy it. Check out Ruff Stuff. They might be a little cheaper all together.
Old 11-04-2011, 09:18 AM
runs-on-4's Avatar
have you ever bought from them? do they ship fast?
Old 11-04-2011, 11:24 AM
scuba's Avatar
Never bought from either company. I've heard tons of great feedback about ruff stuff, which is why I recommended them. Call the company and ask when they'll ship..
Old 11-04-2011, 11:38 AM
xxxtreme22r's Avatar
ruff stuff is also a vender on here. https://www.yotatech.com/forums/f226...ap-kit-239298/
Old 11-04-2011, 02:53 PM
Stuwy123's Avatar
That's a nice looking kit.
I went the homemade route and made my own mounts.
I left the bottoms of the front mounts on for extra support and skid protection (I guess).
I didn't make a rear mount, I just made some longer shackles and mounted them to the stock rear mounts.
I also installed new bushings into my springs, no squeaking what so ever. Makes my buddy with an 06 Tacoma really jealous. Haha.
Bushings were $40, springs were $40 (i think), steel was free.
You'll need to do something with the front because you'll be getting a couple inches of lift. I had to crank the torsion bars all the way to bring it back to stock rake.
I don't know how high it was stock but the top pic is my truck before and the bottom is after. You can see how much lift I got from the fender well gap.
Old 11-04-2011, 05:29 PM
runs-on-4's Avatar
i have a 4inch lift up front? was yours stock height?
Old 11-05-2011, 02:07 AM
95 4Runnin's Avatar
that is a good kit i just got a set of 63in chevy leaf spring im probably going to order those one
Old 11-06-2011, 10:14 AM
Stuwy123's Avatar
My truck wasn't stock height at the time of those pics.
3" body lift (that doesn't change the suspension though)
The first pic was basically flat suspension.
The rear springs only had maybe an inch or two before the bump stops (which it hit them alot).
And the front was basically flat as well.
The front suspension arms were flat and parallel to the ground where as they should be more angled.
The second pic is the same front suspension with 63" chevy springs in the back. Lots of up travel.
Old 11-06-2011, 10:18 AM
Stuwy123's Avatar
I would recommend just installing the rear springs first and then tinkering with the front to get it sitting properly.
Some say that a 4" suspension lift will match a 63 chevy spring swap in the rear. That could be true, all depends on the length on your shackles, if you moved your rear shackle mounts or kept them stock, and of course, how many leafs you have and how worn out they are.
(Mine are 3+1 (3 main leaves plus the overload).
Do the rear spring swap, then worry about the front.
Stuwy123's Avatar
Pirate is your friend.
http://pirate4x4.com/forum/showthread.php?t=20665
Old 08-10-2012, 09:54 PM
travyota39's Avatar
runs on 4 what did you end up doing?
Old 08-12-2012, 07:26 PM
runs-on-4's Avatar
I went with sky's off road kit but lost one of the spring hangers so I bought trail gear hangers
kawazx636
10-06-2021 03:03 PM
TheBFA
02-15-2020 06:55 AM
scott90
10-04-2015 09:21 AM
Thamuel_
Domestic Swaps
10-03-2015 11:15 AM
JookUpVandetti
09-30-2015 08:58 AM
Quick Reply: 63in chevy mounts
