4runner rear window
Figure out why it is not latching. Maybe a seal is sicking out or the latches are not adjusted right or something is loose or worn out. Basically open up the access hatch and watch what happens when someone closes the tailgate and when they push on it to make it latch.
We can't manually raise and lower our windows, it would be great to see an after market kit though to make them manual, like an old Blazer.
Yank your old motor and replace it.
#25
i'm assuming that all of the bolts for the roof are in place? on the driver side, one of the bolts(around the rear seat back/rollbar area) has to be in place in order to ground the system. if you pop off the interior panels you can see it fairly easy, check to see the wires are all connected and in good shape, and make sure the bolt is all the way in, doing its job grounding the system.
#26
1992 4runner tailgate lock malfunction
Camping recently turned into a bugger when I couldn't unlock the tailgate from the inside, with the window down (as you do)... meaning all my stuff under my sleeping platform, accessible only with a lowered tailgate, was stuck out of reach.
I thought the lock might have seized or the handle broken, but when I got home and managed to pull all the junk out of the car and pulled the tailgate cover off under the carpet, I found that everything works okay, but it seems that once everything is put in place and the window goes back up again - yes it blooming well locks itself again. from this awesome forum, I can see its a safety mechanism meant to happen now, but I cannot see why its failing to push the lock back up after the window is all the way fully down again. what am I missing?
alternatively - is there a way to 'trick' or bypass the automatic lock when the window goes back up so there is no lock in place ever again?
I appreciate any help... I'm about at wits end and going to go camping again in a couple of weeks and want to get it sorted asap!
#27
Might be related to #4 below:
- http://www.4crawler.com/4x4/CheapTri...CommonProblems
See if you can load your gear in the back with the access panel off and see if you can see what is going on there, basically try to duplicate the problem scenario. It is all pretty simple mechanisms. See if you can get an idea how all the components operate. You can usually find out the cause of the problem and perhaps a way to bypass the locking feature, too.
06-01-2021 01:51 PM
MMA_Alex
25
04-18-2017 05:07 AM
WTB[WestCanada]: 1989 4runner stock front bumper and other items
lledwod
08-30-2016 01:03 PM
Jnkml
07-06-2015 01:20 PM
