3vze Top End rebuild...W/pics...slowly - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 02-08-2005, 08:13 PM   #1 (permalink)
Morphine's Avatar
Send a message via AIM to Morphine Send a message via Yahoo to Morphine
As you know I'm basically rebuilding my top end. So tonight I finally got started and took some pics. It will be slow going as I'm not a mechanic and started before Drkgypsy made it over(man is he going to have FUN piecing this mess back together with me ). Parts on order, machine shop lined up. Let the dismantling begin.
Angles of the engine area:
Room to work in:
Goal to remove tonight:
Success:
The mess:
__________________
'91 v6 3.0L 4x4 Pickup. Oversized Valves, Ceramic Downey Headers, K&N Cone Filter Knock off, ISR Mod, Pro Comps 33x12.50x15's, 2" BL, Skyjacker Steering Stabilizer,Bilstein's in the corners, Acura Bucket Seats, Custom dye'd Black carpet!
Stereo: Pioneer DEH-P7600MP HU, 4" 2-way Pioneer TS-G1040R, 6.5" 4-way Pioneer TS-A1681R, Sub in progress!!
Morphine is offline
Old 02-08-2005, 08:17 PM   #2 (permalink)
Morphine's Avatar
Sorry for the large pics if needed I'll resize them.
Parts are ordered. Going to a larger valve on the heads. Downey headers and new HP exhaust. 2" body lift and I just found out I'll be getting an early B-Day gift of new skyjacker shocks (currently all 4 corners ride on economy monroe shocks -- Not designed for my yota). Love ya sweety, no, not you guys on the forum...Nothing personal.
The Project has began
-=Morphine=-
EDIT:::
Is it common for this gasket to be cracked into 3 pieces when you remove the air intake manifold?
__________________
Morphine is offline
Old 02-08-2005, 08:28 PM   #3 (permalink)
bike4miles's Avatar
Send a message via Yahoo to bike4miles
What is a top end rebuild? Not sure about the gasket, never had my 3.0 appart that far before I sold it although I needed to because the valve cover on that side leaked. Doesn't look TOO bad but sill a lot of work for a valve cover!
__________________
--Miles
Sold
'91 4runner, 22re, 5 spd manual, 180,000 miles,
cone filter, Downey 1.5"HD coils, SkyJacker Nitrogens, Magnaflow Exhaust, Stull grill, Clears all around. Check out my sound proofing project and other mods:
My 4runner page
My 2006 Camry page
I'm a Myspace Addict!
bike4miles is offline
Old 02-08-2005, 08:33 PM   #4 (permalink)
Morphine's Avatar
Well I'm calling it a Top End Rebuild.
Bike4miles, as the title says, that's what I'm callingit. Machining the heads, valve job, adjustment, new gaskets, hoses, etc.
Basically Cylinder #6 is shot to hell and the other 5 are weak. Hope that explains my intentions.
-=Morphine=-
__________________
Morphine is offline
Old 02-08-2005, 08:36 PM   #5 (permalink)
ChickenLover's Avatar
Quote:
Originally Posted by Morphine
EDIT:::
Yes. I've removed my plenum many times and it's always in 2-3 pieces. You oughta see what my engine compartment looks like right now. Good luck dood!
__________________
95 4Runner, 3VZE , 141k, 4WD, Auto. (Head gaskets replaced at 106k)
ChickenLover is offline
Old 02-08-2005, 08:42 PM   #6 (permalink)
Great Pics! This weekend, I'm going to start doing the same thing... My 91, V6 is showing a knock sensor code and I finally decided to take-on the project in replacing both sensor and wire. Thanks
westca707 is offline
Old 02-08-2005, 08:45 PM   #7 (permalink)
bike4miles's Avatar
Ok, got it. Hey ChickenLover, is that your radiator I see still mounted? How did you get all that stuff out without smashing it? That's always the first thing I take out.
__________________
--Miles
Sold
My 4runner page
My 2006 Camry page
Old 02-08-2005, 08:51 PM   #8 (permalink)
Quote:
Nah, the radiator was the first thing to go. That's just the 'thing' that sits in front of the radiator. Sorry, I can't think of what it's called.
__________________
Old 02-08-2005, 10:24 PM   #9 (permalink)
Ganoid's Avatar
AC condensor is whats still mounted.
__________________
1990 Xcab beast of burden
3.0 Rebuild/Precision balanced w/OS valves
Custom ported/welded Intake manifolds
Downey headers, Jacobs Ign
4" Trail Gear SAS + rear Kit
R151 + Dual cases (2.28+4.7)
5.29's,Tru Trac/Lockright on 35 BFG's
140A GM CS144 alt/Hyd assist steering
DOA Racing = $1200 lesson in who NOT to deal with
Ganoid is offline
Old 02-09-2005, 12:20 AM   #10 (permalink)
Morphine's Avatar
OK help please.
Midnight wrenching or the Haynes manual I'm using....but something doesn't seem right. Alright, Air intake manifold (plenum) is off, so are the valve covers for both sides. Next the manual says to remove the "intake Manifold" between both sides. Ok, however I still have the timing belt and cover and everything else on up front - minus the fan and shroud still on. The Intake manifold appears to be connected to these items. Am I wrong? Should I remove the timing belt and upfront pulley's and belts, then the intake manifold? Anyone off tomorrow and want to come up and help? Pizza and soft drinks? If it gets done BEER!!!
Please guide me O'ye wonderful and full of the Yota knowledge followers of yotatech.
-=Morphine=-
__________________
Morphine is offline
Old 02-09-2005, 01:59 AM   #11 (permalink)
nunsa's Avatar
-=Morphine=-
Get your T-belt off. One quick tip also: Make sure you replace your knock sensor and wire! If not it will almost gaurenteed to throw a code 52 after you get her back together. There's many ways to dismantle a 3.0, the 1st thing I would have taken off was the T-belt, starting upfront and moving backwards. It's pretty much up to you. The advice I use to give to people when taking a 3.0 apart was: take pictures and get yourself some pieces of cardboard, the cardboard was for to put the bolts from the heads in order in which they came out,and other bolts (unless your replacing them), That way you'll exactly where they go. Your doing a fine job! Good Luck!
__________________
The Master Toyota Tech,
2003 Toyota Tacoma xtra-cab, 3.4 V6, 5speed,4x4, TRD w/OffRoad Package.
"Expert on the 3.0 Engine!"
Disclaimer: As a former TOYOTA TECHNICIAN I authorize this post/reply
US MARINE*** SEMPER FI
nunsa is offline
Old 02-09-2005, 06:33 AM   #12 (permalink)
Bumpin' Yota's Avatar
Send a message via AIM to Bumpin' Yota
Agreed, and yes that lower intake plenum has the #2 idler for the timing belt attached to it. Pull the timing belt like nunsa said, (after setting the engine to TDC) then attack you cam gears (goodluck hehehehehe they are nasty SOBs to get off) only then can you take the rear timing covers off, then the fuel lines/rails/injectors, then lower intake.
I did find a place online that sells new heads that are ported polished with oversized intake and exhuast valves, AND have 4 cam profiles for this engine!!! The heads come already set up to go. The cost however is 1200 + 600 core charge!! :eek:
__________________
3vze, 4x4, sr5, 90, auto, LSD
2x dB Drag World Finalist
2003 Nopi Nat. Street B champ
2004 SBN Street C champ
2004 SBN Advncd NW Champ
2004 Former WR Holder in NW.
SPL: 159.8db @ 42hz
In loving memory of Jamie Riggs 5/15/85 - 10/8/04
Bumpin' Yota is offline
Old 02-09-2005, 09:41 AM   #13 (permalink)
Morphine's Avatar
thanks, now back to the wrenching.
Ok, timing belt and accessories are next. I already set TDC and marked it, so I'm good there. I've heard from many sources to replace the knock sensor and wire now so that's been added to the list.
Bumpin' yota - Out of my price. Thats almost the amount that this repair is gonna cost me. I would like to check them out if you have a link. Curiosity killed the called.
I have carboard and post-it notes labeling everything and my digicam is going crazy. Putting here back together is going to be a PITA.
Is there an acceptable number of parts that can be leftoff and she'll still run fine? j/k
-=Morphine=-
__________________
Morphine is offline
Old 02-09-2005, 10:23 AM   #14 (permalink)
4Hummer's Avatar
You'll LOVE your skyjacker Shocks (I do) DOnt foget to replace the steering stablizer while your at it.
__________________
Michael
1991 4Runner 22RE.
CHOP
www.obsessiveoffroadclub.com
4Hummer is offline
Old 02-09-2005, 08:15 PM   #15 (permalink)
Morphine's Avatar
Projects getting bigger than I thought
Ok, with so much torn off the engine I decided to take a stab at some body work while I'm at it. In tearing down my 3vze I've found the fuel injectors (2 of them) were held to the electrical connector with zip ties. Completely fouled up I'll be sending them for a cleaning and comlete flow test to Cruzinperformance. Heads will be going to the shop on friday. Here are some more pics...
Timing belt
Is this the knock sensor?
Valve covers off
Dirty and carbon/crap build up.
Start to work on the body
Close up of the dent fron behind the fender
__________________
Morphine is offline
Old 02-09-2005, 08:48 PM   #16 (permalink)
Niiice! Good luck with that crank pully and the cam pullys!
That website you wanted that has:
Performance Heads w/4 cam lobe options
Big Bore TBs
Forged cranks
Forged rods
Cast race prepped rods
Forged pistons
Moly ring
Head Studs ----- something you and I should get
3vze STROKER KIT!!
That site gives me ALL kinds of ideas!!
EDIT: Whoops forgot the URL...LOL
http://toyotaperformance.com/3_0l.htm
Anyone got a few grand I can have?
__________________
SPL: 159.8db @ 42hz
Old 02-09-2005, 08:51 PM   #17 (permalink)
PS - yes that's the knock sensor. You should REALLY change out those steel freeze plugs....I bet they are rusting like a mofo...
__________________
SPL: 159.8db @ 42hz
Old 02-09-2005, 08:52 PM   #18 (permalink)
Send a message via MSN to dragon564
Morph,
Sorry man I forgot to send you this really cool web site. You can print out the steps for taking apart the head and many other things. http://www1.autozone.com/servlet/UiB...3d8017957f.jsp
it is should be one line in the address bar with no spaces and type it just like you see it here. I have printed it out a couple of times (only the part for the 3vz) and have the pages real handy while I working. I have checked them against the chiltons I have; and for the most part excatly the same. the printed pages are cool cause I do not have to worry about greasy finger prints on the import parts of the book.
Your tracking right...good luck
dragon564 is offline
Old 02-09-2005, 08:54 PM   #19 (permalink)
KING's Avatar
Replace knock sensor and wire when doing t-belt replacemnt?
KING is offline
Old 02-09-2005, 09:02 PM   #20 (permalink)
Morph,
sorry as I read it online it hacked up the web address. let me try again
www1.autozone.com/servlet/Uibroker?ForwardPage=
/az/cds/en_us/0900823d/80/17/95/7f/
0900823d8017957f.jsp
http://www1.autozone.com/servlet/UiB.../cds/en_us/090
0823d/80/17/95/7f/0900823d8017957f.jsp
try that...should work better
Dragon
Old 02-09-2005, 09:02 PM   #21 (permalink)
Morphine's Avatar
Encouragement
Thanks for the link Bumpin'Yota I've checked them out. Brass freeze plugs are ordered as well as what seems like everything else. I contacted Toyota stealership and they quoted me:
part no. 82219-89103 wire sensor for 11.47
part no. 89615-20010 knock sensor for 179.28
Can anyone recommend a better price or place or just stay with the stealership?
Man Ifeel so vulnerable just revealing my dirty/abuse engine to everyone here. Bumpin' if i'm ever in your area again we'll have to get together and wrench/drink/yota
Dragon thanks for the link, my haynes manual will appreciate it (but my printer will no longer be my friend after I'm done printing it out a 100 or so times).
Thanks
-=Morphine=-
__________________
Morphine is offline
Old 02-09-2005, 09:15 PM   #22 (permalink)
Hey if you need the Toyota Factory Service Manual for removing the heads and reinstalling them as well asdissassembly, just gimme an email addy that can take a BIG attachment. Lots of pics (ok drawings lol) are included.
__________________
SPL: 159.8db @ 42hz
Old 02-09-2005, 09:16 PM   #23 (permalink)
Morph,
don't feel bad bout the motor.... I could always post the picture of my old one with the number one piston so low in the cyl that you can tell the con rod is just not there.....Your in California so we can just say it like this.....
Yes it the prior care provider could have down more, but counseling is being conducted, and everything will be better in a few more sessions
Old 02-10-2005, 02:00 PM   #24 (permalink)
KING's Avatar
Perhaps I ought to rephrase my question because of comprehendible issues.
When is it mandatory to replace the knock senser? When doing doing the timing belt replacement or when doing engine re-build?
Is it not quite clear as to when to replace it at the above mention.
I will be replacing my timing belt in the next few segments and I would like to know if to tackle it then or not.
Highly appreciate a generous and non-effortless response.
KING is offline
Old 02-10-2005, 03:37 PM   #25 (permalink)
Eric's Avatar
I'm wondering the same thing. I want to make sure my knock sensor is not working before I plump down 200 on a new one...
on another note, everyone is saying to ground the knock sensor wire to the block. this seams wierd since there is only one wire comming off the knock sensor, and it doesn't look thick enough to be shielded.
can you guys give better details to this grounding deal?
__________________
Karl Kraus --Education is a crutch with which the foolish attack the wise to
prove that they are not idiots.
Eric is offline
Tags
0927854012, 3vz, 3vze, 4runner, end, engine, heads, kit, knocking, rebuild, rebuilding, sst, tool, top, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Bad MPG after top end rebuild and y pipe mod!! Chief_Yota 86-95 Trucks & 4Runners 25 06-14-2007 09:38 AM
2 injectors blocked after top end rebuild ,can i do this? Chief_Yota 86-95 Trucks & 4Runners 5 06-03-2007 09:19 PM
3vze top end rebuild (head bolts) Desert Rat 86-95 Trucks & 4Runners 10 01-01-2006 09:24 AM
Top end rebuild? RIPPER 95.5-2004 Tacomas & 96-2002 4Runners 1 02-01-2005 06:21 PM
2009 InternetBrands, Inc.
