3VZE LH Fender Ground
Old 07-04-2009, 04:40 PM
kagrimm's Avatar
Hi,
I am replacing the 3.0 engine in my 94 4Runner. During the transfer of parts I broke off the grounding strap that connects to the drivers side fender. According to the wiring diagram it grounds the ignition noise filter (which I believe is the plug which connects to a capacitor/condensor next to the ignition on the fender), daytime running light resistor (I don't have daytime running lights and don't see a connection for them on the strap), and it connects somewhere on the block/header. My question is where on the block/header does the strap connect. I think it broke off the metal bracket which is bolted to the upper left side of the LH head between cylinder 2 & 4 but need confirmation.
Thanks,
KG
Old 07-04-2009, 04:51 PM
toylocost's Avatar
Location: Yotatech, because Pirate is too expensive. NorCal.
Just went out and looked at mine. It is attached to the head above the exhaust manifold, and below the valve cover.
Old 07-04-2009, 04:54 PM
kagrimm's Avatar
Thanks for your help.
Old 07-05-2009, 12:11 PM
wighty's Avatar
I melted both my grounds under the hood... one that goes to the block and the one that goes to the PS fender.... I suggest using a heavier gauge ground.... im now using a 4ga. ground.... I was stuck in nowhereland Hunting... good thing the truck wouldnt start... since I shot my first bear while waiting for grounds to show up from my buddy
punks_is_4x4
05-31-2016 06:03 AM
89fourrunner
02-17-2016 06:52 AM
JHalcyonM
09-14-2015 01:10 AM
gp66
09-07-2015 08:29 AM
viesail
09-05-2015 04:23 AM
Quick Reply: 3VZE LH Fender Ground
